Topic: SIMCOM SIM900 GSM shield, AT+CHFA=1 returns error. Desperate! (Read 128 times) previous topic - next topic
Stoil
Title.
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); // RX, TX
Serial.begin(19200);
mySerial.begin(19200);
mySerial.write("AT+QAUDCH=1");
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
I can call, Ican text, I can answer but no sound and other's don't hear anything. I have aworking pair of headphones and a mic. Yesterday when I got called and had the same headphones plugged in - I could hear the 8bit music but ever since then nothing.
I've tried setting Carriage return & Both NL & CR, doesn't work.
some results:
AT+CHFA=?
+CHFA: (0 = NORMAL_AUDIO, 1 = AUX_AUDIO)
AT+CHFA?
+CHFA: 0
AT+CHFA=1
ERROR
AT+CHFA=1\r
ERROR
However, this code - https://gist.github.com/tahmmee/1927e6b21680948657f732db1b75048b
has some startup commands. There is a command AT+QAUDCH=1. In some SIM900 documentations I saw this command is used to change audio channels, while some other documentations show AT+CHFA = 1. In my case both don't work. However, when I run this code, the command AT+QAUDCH=1 returns OK but I still cannot hear anything! I tried adding another AT+QAUDCH=1 in the array just to see if it's gonna return an OK - well, it returned an ERROR which is even stranger!
First day I managed to receive a call I had sound come out of the same headphones. Now there is no sound. Microphone also doesn't work. Many of the listed commands don't work either, just return ERROR.
I'm really frustrated now, haven't made any progress the last 2 days..
delegacooo
Can you get more information for ERROR?
I think  the datasheet describe about a thing which you should do  against your type error.
Stoil
It just says ERROR. I saw some commands about extended error report but couldn't get anything except "ERROR". I tried resetting to manufacturer settings in case I've messed something up but nope, still doesn't work. Calls, sms are flawless.
KASSIMSAMJI
1. enough delay after Serial.println() ?
2. flashing it may solve your issue
Electrical Engineer
Stoil
1. Sorry, what ?
2. Can you recommend a recent UP-TO DATE tutorial ? This is the one I got - http://cdn.shopify.com/s/files/1/1877/5421/products/sku_475131_1_1024x1024.jpg?v=1512191559
SIMCOM SIM900
Thanks in advance.
KASSIMSAMJI
1. Sorry, what ?
SIMCOM SIM900
Thanks in advance.
1. i meant providing enough delay() after Serial.prints sent to your sim 900, otherwise you might wan to check this
2. (a) http://dostmuhammad.com/blog/firmware-upgrade-for-sim900-gsmgprs-modem/
   (b)  https://simcom.ee/documents/?dir=
i am sure some AT commands errors can be solved with flashing (upgrading the FW), but you check the current one , and find the latest on that web
Electrical Engineer
Stoil
Hello,
thanks for the response.
1. I still do not understand. Is delay needed or not ? Why ?
2. Thanks. I checked it out and it doesn't seem complicated. I'll try for a few more days and will flash it as a last resort.
Regards
