Topic: Array of IRremote objects (Read 188 times) previous topic - next topic
UKHeliBob
In another thread in which I am involved we have just about got to the point where the OPs requirements regarding use of an IR receiver have been met.  However, the OP of the thread has just made it known that the code needs to work with 4 separate IR receivers.  Oh, joy !
My thoughts immediately turned to creating an array of IRrecv objects so I tried this
Code: [Select]
#include <IRremote.h>
IRrecv irrecv[] = {12};
decode_results results;
  Serial.println("Enabling IRin");
  irrecv[0].enableIRIn();
  Serial.println("Enabled IRin");
  Serial.println(irrecv[0].decode(&results));
  if (irrecv[0].decode(&results))
    Serial.println(results.value, HEX);
    irrecv[0].resume();
  delay(100);
Before anyone points it out I know that the array only has one element.  The program works as expected but if I add a second pin number to the object creation like this
Code: [Select]
IRrecv irrecv[] = {12, 11};
then
Code: [Select]
irrecv[0].decode(&results)never returns true
Has anyone got any ideas how to get this working or can spot anything obvious wrong when the array has 2 or more elements in it ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Danois90
Have you tried to enable debug mode for the library? Have you tried to explicitly declare an array size (IRrecv irrecv[2] = {12, 11};)?
Instead of mocking what's wrong, teach what's right! ;)
When you get help, remember to thank the helper and give some karma!
Please, do NOT send me any private messages!!
LightuC
#2
Jan 12, 2019, 12:26 pm Last Edit: Jan 12, 2019, 12:30 pm by LightuC
You can't use the IRremote library for more than one instance. I quickly checked the library implementation and it seems they are using an interrupt to receive the raw data. However, the interrupt routine samples the pin contained in the global irparams struct:
Code: [Select]
// Allow all parts of the code access to the ISR data
// NB. The data can be changed by the ISR at any time, even mid-function
// Therefore we declare it as "volatile" to stop the compiler/CPU caching it
EXTERN  volatile irparams_t  irparams;
Therefore, when you create your second instance of IRrecv, the pin in irparams will be set to 11. Every instance of IRrecv will now try to receive data from that pin.
Code: [Select]
IRrecv::IRrecv (int recvpin)
irparams.recvpin = recvpin;
irparams.blinkflag = 0;
UKHeliBob
Quote
Oh dear.  So that is my idea of using an array of objects scuppered
LightuC
Yes. You could, of course, change the IRremote library implementation to support multiple instances. I'm not particular happy about this approach from the IRremote library developers. If you can only use one instance, it should be impossible to create more than one (e.g. implement it as a singleton).
UKHeliBob
Quote
That had occurred to me, but I am unlikely to take the idea forward unless I suddenly get interested
marco_c
Is there anything stopping all receivers connected to the same pin? I seem to remember that technique was used somewhere to connect receivers for different IR frequencies.
Another technique that I have used is to only power the receiver when you want it to receive an IR signal by connecting the receiver voltage pin to one of the MCU output pins. Set the pin HIGH when the receiver should work. In my application the current was well within the MCU pin limits, but an interposed transistor would solve that issue if it arises. This may not work, of course, if you need to be receiving all the time.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
UKHeliBob
