Topic: 4x4 Tactile Pressure Sensor Information (Read 155 times) previous topic - next topic
hbarot
Hello,
I was recently provided a 4x4 tactile pressure sensor. it is composed of 4 row and 4 column pads and has 8 pin as seen in the picture attached. There is no information or identification regarding this product. I Would appreciate any information on this sensor. Thank you.
Paul_KD7HB
Hello,
Does Google show you any pictures of that device? If so, follow the links to the source.
Paul
hbarot
no i couldnt even find any images of that on the internet.
Paul_KD7HB
Then it must be custom device and you will need to use your Ohmmeter to trace out all the connections. Put a piece of tape on each pin and number them, then use the meter to see which numbers are connected to another. Make a spreadsheet showing the results.
Paul
hbarot
After much testing, it seems like it is a combination of 4 FSR sensors, with VCC supplied to column pins one at a time, and then reading the row pins in voltage divider configuration. I will need some kind of multiplexing code to read the values from all the columns.
hbarot
Paul
Thanks for the information Paul
outsider
Might be just a 9 spot keypad, have you tried the keypad library?
https://playground.arduino.cc/Code/Keypad
Willpatel_Kendmirez
And apart from the library itself, there's also a tutorial which may help you sort out the pins if necessary.
(I bought a membrane keypad last week, and thought it was stuffed as supplied. I set my meter to beep, and of the 16 buttons only 4 or so caused a beep. But luckily I noticed out the corner of my eye that the actual value on the meter was changing: turns out most of the buttons have resistance above (both of) my meter thresholds, yet good enough to work with the library.)
