Topic: code for proximity sensor to detect and rotate a servo motor help needed! (Read 493 times) previous topic - next topic
NINZJAZZ
i know some code of proximity but i dont know anything about servo code help me insert servo code inside this if value is 1 rotate 90degree right whereas if value is 1 rotate left 90degrees i want something like this pls help
Code: [Select]
int limitSwitch = 13;
int state = LOW;
  pinMode(limitSwitch,INPUT);
    int val = digitalRead(limitSwitch);
Willpatel_Kendmirez
So just to check, you want it to go to two different places with the same input?
Or should one of those be "0"?
First, let's discuss your switch. Do you have a pull down resistor on it? (Asking since you have it pinMode()-ed as INPUT, so it would be wired from pin to 5V?) If not, rather change that to INPUT_PULLUP and wire the switch from pin to ground. Then when switch is open,pin is high; when it is closed, pin goes low.
Second, have you digested the servo examples?
Willpatel_Kendmirez
By the way, what you are picturing as 90 left and 90 right will be 0 and 180 (or 180 and 0) for the servo library, with 90 in the middle.
NINZJAZZ
yeah u are right 1 of them should be 0 that is my typo sorry i have 2 1* k resistor in proximity sensor circuit it is working it would be wired to 5v by breadboard if u can suggest some good ideas to connect explain to me please
and those servo examples i digested only potentiometer one second one got over my head
sorry for my bad english
Willpatel_Kendmirez
The below code swings the servo side to side when you press or release a button. I have the button from pin 14 to ground, and use input pullup.
Code: [Select]
// side to side servo with a button
#include <Servo.h>
Servo myServo;
byte servoPin = 10;
byte buttonPin = 14;
byte servoPos;
  myServo.attach(servoPin);
  pinMode(buttonPin, INPUT_PULLUP);
} //setup
  if (digitalRead(buttonPin) == HIGH)
    myServo.write(0);
    myServo.write(180);
} //loop
NINZJAZZ
can u tell what extra parts i would need rn i have 1 breadboard mega2560 5 1k ohm resistor please also tell how to connect them
NINZJAZZ
pls tell me additional parts and tell me how to put it together i did the servo and ultrasonic but inductive sensor would take resistor as i heard pls tell how should put them
groundFungus
The term "inductive sensor" is too general for us to be able to help you.  Post a data sheet for the sensor and we may be able to help.
NINZJAZZ
CHPSS570 Lj12A3-4-Z/Bx Inductive Proximity Sensor Detection Switch Npn Dc6-36V 4mm Normally Open Proximity SwitchVoltage: dc 6-36v, output current: 300ma, 3 wire
Polarity: npn, output status: normally open
Dimension: m12x10x55mm
Detection objects: conductor, detection distance: 4 mm
would this help?
pert
Please don't cross post!
http://forum.arduino.cc/index.php?topic=590778
Duplicate posts waste the time of the people helping you. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread. This behavior is not very respectful to the people you're asking for assistance. Just because they  give their  time freely doesn't mean it has no value.
In the future, take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
Coding Badly
Chuir mi na snàithleanan còmhla.  Dà uair.
Coding Badly
NINZJAZZ
Code: [Select]
#include <Servo.h>  //add '<' and '>' before and after servo.h
float metalDetected;
int proximitySensorValue;
int proximitySensorPin = A1;
int servoPin = 4;
int servoAngle = 0;   // servo position in degrees
Servo servo;
const int trigPin = 2;
const int echoPin = 3;
long duration;
int distance;
  servo.attach(servoPin);
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  proximitySensorValue = analogRead(proximitySensorPin);
  metalDetected = (float) proximitySensorValue*100/1024.0;
  Serial.print("Object detected: ");
  Serial.print(metalDetected);
  Serial.println("%");
it should detect metal with the inductive sensor however this is the out put in the serial monitor
Code: [Select]
Object detected: 99.90%
Object detected: 0.00%
Object detected: 61.82%
Object detected: 61.04%
Object detected: 7.71%
Object detected: 30.76%
Object detected: 80.76%
Object detected: 57.91%
Object detected: 35.84%
in a constant loop even when the sensor is not close to a metal i want it to just tell  me that metal is detected or not if metal is detected show 1 if not send 0 simple as that i have atached the pin to analog and connected the inductive sensor with a separate power supply 9v for whereas arduino is supplied with the usb and motor is by 5v
please help
groundFungus
#13
Jan 16, 2019, 04:08 pm Last Edit: Jan 16, 2019, 04:09 pm by groundFungus
I think that we need a data sheet for the sensor and a schematic showing how it is wired to the Arduino.  I suspect a floating input.
septillion
I agree. Most induction sensors I know are open collector and not analog.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
