Topic: Arduino Uno not providing power? (Read 2372 times) previous topic - next topic
Maretaga
My Arduino Uno arived in the mail today (yay ^^) so I'm trying it out right now. I uploaded the standard blink-file to the Uno (the one that makes the LED next to pin 13 blink) and it worked fine. However, I cannot use it to blink a LED on a breadboard. I tried changing pin 13 to 12 in the code and then compiling and uploading it again, but this also has no effect. Turning the LED around doesn't work either and neither does using the the 3,3V or 5V pins. Does a USB-powered Uno provide power at all, or have I missed something?
retrolefty
You will have to show us how you are trying to wire up the led (be sure to use a series resistor) to tell you where you might be going wrong. Assuming you can upload to the board and your using the blink sketch it probably isn't a sketch problem, but posting your actual sketch is also a good idea.
Lefty
Maretaga
The wiring is simply copied from this:
http://arduino.cc/en/Tutorial/Blink
And the code:
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
As mentioned above, this one works for the LED on the board, but not for LED's that I try to connect to the pins.
Another possibly important detail:
When I connect a wire to the 5V, the green power-LED turns off (and disconnecting the wire turns it on again).
Luigi_xp
try to simple put a led direct on pin13 and gnd of arduino without resistor. it works?
retrolefty
Please ignore this suggestion. Wiring a led to pin 13 without a series resistor will short out the output pin and damage the 328 controller chip.
Lefty
retrolefty
Quote
What is the other end of the wire going to? You are somehow shorting the power on the board. Are you sure you are following the wiring correctly. Are you using a resistor in series with your diode?  What value resistor?
Lefty
Luigi_xp
#6
Apr 20, 2011, 10:45 pm Last Edit: Apr 20, 2011, 10:48 pm by Luigi_xp Reason: 1
Lefty
really no
this not short or damage atmega328.
retrolefty
Quote
Yes it will. To prove it to yourself measure the current you are allowing to flow through that led. Then note that the absolute maximum safe output pin current is 40ma.
Lefty
Luigi_xp
20ma that should not damage the chip.
retrolefty
How is the led current being limited to 20ma?
Lefty
Luigi_xp
Lefty
the led only need 20ma to power up; a exemple: if you plug a 500ma usb on a arduino that need 40ma alone, the arduino will take only 40ma from usb. this is basic eletrical enegering.  :)
retrolefty
Quote
I'm afraid your basic electrical engineering needs a refresher course. 20ma is a pretty normal recommended continous current for a LED. However the LED does not determine this value, the current must be controlled external to the LED, normally with a series current limiting resistor. Once a LED has greater then it's forward voltage drop applied it will draw excessive current unless controlled externally.
I really don't care if you get this or not, what I'm trying to prevent is other newcomers reading your post and thinking they don't require the use of series resistors with LED because that will lead to damaged arduino boards and burned out LEDs.
Lefty
Luigi_xp
Quote
Lefty
yes, we not need resistor on arduino pins because of low current, but if we plug a led directly into arduino 5v or other power soucre we need a resistor. finished this.
Jack Christensen
Quote
...what I'm trying to prevent is other newcomers reading your post and thinking they don't require the use of series resistors with LED because that will lead to damaged arduino boards and burned out LEDs.
Agree completely.  Robert Faludi does this in his book Building Wireless Sensor Networks.  Hooks LEDs directly to the Arduino and also to XBees.  Raised my eyebrows a bit.  It would seem the pin output circuitry limits the current to a sane level.  Maybe it's OK sometimes, maybe it's marginal, maybe it depends on the LED, etc., but I ain't doing it, it's Bad Practice, and should definitely be discouraged.  If nothing else, it's dissipating more power inside the MCU than necessary.  Does make me curious, though.  Luigi, does the MCU get warm?  What if you hook LEDs directly to 8 or 10 pins and turn them all on simultaneously?
Maretaga
In the meantime, I'm still trying to find out what I'm doing wrong. I tried connecting the uno to a different USB-port, but this has no effect either.
The exact details of how I connected this:
Jump wire from pin 12 (uno) to pin 1A of the breadboard.
Resister (220 ohm) from pin 1B of the breadboard to pin 1F of the breadboard.
LED from pin 1G of the breadboard to 1H
Jump wire from pin 1J of the breadboard to the GND-pin above pin 13 of the uno.
I have also tried setting this up along the 10th row of the breadboard.
I would like to present a picture, but I have no camera around at the moment.
