Topic: unexpected blinking led (Read 972 times) previous topic - next topic
histteval
hi, i'm new with arduino. I've just got my board, connected a led to pin 12 with a 1kohm resistor and loaded a code to turn on the led. But when the program starts the led starts to blink all the time. Is this normal?
if i connect the led to pin 13 and turn it on, the on board led turns on and stays like that, but the led connected to the pin blinks. i don't know if this is normal. how do u do to have a non-blinking led?
thank you for your help
RuggedCircuits
There are self-blinking LED's out there. Any chance you got one of those? Do you know where you got the LED from?
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Luigi_xp
1kohm is too much for a led. for blue, white and green leds use a 100ohm. for other colors and low brightness use 220ohm.
James C4S
Quote
No, 1Kohm is probably fine.   In fact, the LED on the Arduino's Pin 13 has a series 1Kohm.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
histteval
thanks. i tracked back the series number of the led and found out its a blinking led.
thank you very much for the help :)
