Loading...
Pages: [1]   Go Down
Author Topic: Problem with code  (Read 223 times)
Offline Offline
Newbie
View Profile
Hi, I am currently making a ROV with arduino. I am using a code I found on the internet. This is the code:
Code:
#include <string.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 110 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
Server server(80);
int ballastfloodpin = 4;
int ballastdrainpin = 2;
int rightbilge = 3;
int leftbilge = 5;
int reversebilge = 7;
int forwardbilge = 9;
int val = 0;
boolean LEDON = false;
String readString = String(30);
void setup(){
Ethernet.begin(mac, ip, gateway, subnet);
pinMode(ballastfloodpin, OUTPUT);
pinMode(ballastdrainpin, OUTPUT);
pinMode(rightbilge, OUTPUT);
pinMode(leftbilge, OUTPUT);
pinMode(reversebilge, OUTPUT);
pinMode(forwardbilge, OUTPUT);
digitalWrite(ballastfloodpin, LOW);
digitalWrite(ballastdrainpin, LOW);
digitalWrite(rightbilge, LOW);
digitalWrite(leftbilge, LOW);
digitalWrite(reversebilge, LOW);
digitalWrite(forwardbilge, LOW);
void loop(){
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 30)
readString.append(c);
if (c == '\n') {
floodstatus();
drainstatus();
rightstatus();
leftstatus();
reversestatus();
forwardstatus();
readString="";
client.stop();
delay(100);
void htmlcontent(){
client.println("HTTP/1.1 200 OK"); // now output HTML data starting with standart header
client.println("Content-Type: text/html");
client.println();
client.print("<body>");
client.println("<br ><br >");
client.println("</body></html>");
void floodstatus(){
if(readString.contains("L=1")) //lets check if LED should be lighted
digitalWrite(ballastfloodpin, HIGH); // set the LED on
digitalWrite(ballastdrainpin, HIGH);
Serial.print("DIVE");
}else{
void drainstatus(){
if(readString.contains("L=2")) //lets check if LED should be lighted
Serial.print("SURFACE");
}else{
void rightstatus(){
if(readString.contains("L=3")) //lets check if LED should be lighted
digitalWrite(rightbilge, HIGH); // set the LED on
delay(6000);
Serial.print("RIGHT");
}else{
void leftstatus(){
if(readString.contains("L=4")) //lets check if LED should be lighted
digitalWrite(leftbilge, HIGH); // set the LED on
delay(6000);
Serial.print("LEFT");
}else{
void reversestatus(){
if(readString.contains("L=5")) //lets check if LED should be lighted
digitalWrite(reversebilge, HIGH); // set the LED on
delay(6000);
Serial.print("REVERSE");
}else{
void forwardstatus(){
if(readString.contains("L=6")) //lets check if LED should be lighted
digitalWrite(forwardbilge, HIGH); // set the LED on
delay(6000);
Serial.print("FORWARD");
}else{
When I put it in arduino 0022, I get these errors:
Code:
etch_apr22a.cpp: In function 'void loop()':
sketch_apr22a:101: error: 'class String' has no member named 'append'
sketch_apr22a.cpp: In function 'void floodstatus()':
sketch_apr22a:205: error: 'class String' has no member named 'contains'
sketch_apr22a.cpp: In function 'void drainstatus()':
sketch_apr22a:235: error: 'class String' has no member named 'contains'
sketch_apr22a.cpp: In function 'void rightstatus()':
sketch_apr22a:265: error: 'class String' has no member named 'contains'
sketch_apr22a.cpp: In function 'void leftstatus()':
sketch_apr22a:291: error: 'class String' has no member named 'contains'
sketch_apr22a.cpp: In function 'void reversestatus()':
sketch_apr22a:317: error: 'class String' has no member named 'contains'
sketch_apr22a.cpp: In function 'void forwardstatus()':
sketch_apr22a:343: error: 'class String' has no member named 'contains'
I saw a post on this forum that said that it might solve the problem by using a version older than arduino 0019. I put the same code in arduino 0018. It gave me these errors:
Code:
java.lang.NullPointerException
at processing.app.debug.Compiler.compile(Compiler.java:75)
at processing.app.Sketch.build(Sketch.java:1412)
at processing.app.Sketch.compile(Sketch.java:1203)
at processing.app.Editor$44.run(Editor.java:1807)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Could someone help me understand what is not working in my code, I do not understand the errors I get. Thank you for your help.
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
What is so hard to understand about the message "error: 'class String' has no member named 'append'"?
There is a String class. You are creating an instance of the class:
Code:
Then, you are trying to call the append() method:
Code:
The string class does not contain a method called append(). It does, however, contained on called concat() that does the same thing that append() used to.
The String class does not contain a method called contains(), either.
Code:
http://arduino.cc/en/Reference/StringObject
Choosing a suitable replacement is left as an exercise in brainpower.
Logged
Pages: [1]   Go Up
Print
Jump to:
