Loading...
Pages: [1]   Go Down
Author Topic: Can't upload sketch on Uno  (Read 405 times)
Offline Offline
Newbie
View Profile
compiles blink fine, but when upload to I/O board i get:
Binary sketch size: 1108 bytes (of a 14336 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
this is on vista 64 bit
its getting power and the LED which is connected to pin 13 is blinking
The driver looks ok, when I go to Tools-serial ports it points to port3
And the board is not hooked to nothing except the USB
Thank you
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Close the Arduino IDE.  Disconnect the board.  Start the Arduino IDE.  Which serial ports are listed under the Tools menu?
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Did you install the device drivers?
Logged
Offline Offline
Newbie
View Profile
Hello
windows vista automatically installed the device drivers via the web.
and what do you meen by "Close the Arduino IDE"?
and there is onely one port listed under the Tools menu
that is port3
Thank you.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
It is very unlikely Windows installed the correct driver.  Step #4...
http://www.arduino.cc/en/Guide/Windows
http://www.arduino.cc/en/Guide/Windows#toc4
Quote
If the IDE is running, click the [X] in the upper-right corner to close it.
Quote
and there is onely one port listed under the Tools menu that is port3
The driver is not installed.
Logged
Offline Offline
Newbie
View Profile
it works
Thank you for your time
Logged
Pages: [1]   Go Up
Print
Jump to:
