0
Offline
Newbie
Intermediate Arduino user
« on: April 20, 2011, 07:46:24 pm » |
I don't know if this is the right place to post this, but i was wondering if someone could create a library out of this file for me, every time I try it never works. I made a program to read/write to a RAM chip with 8 addresses pins and 4 I/O pins, the one defined in the integers is the AM9111. You may change anything including the voids and integers if it will make it easier. Here is the code: int addr[] = {0,1,2,3,4,5,6,7}; //address pins int od = 12; //Output Disable pin; to read, must be low int we = 13; //Write Enable pin(in this case on inverted write enable); to write must be low int io[] = {8,9,10,11}; // Input/Output pins // ^LSB ^MSB int ios[] = {0,0,0,0}; //I/O Storage, used to store arduio arduino input bits
void w(int b0, int b1, int b2, int b3) //Write to RAM { pinMode(io[0],OUTPUT); pinMode(io[1],OUTPUT); pinMode(io[2],OUTPUT); pinMode(io[3],OUTPUT); digitalWrite(od,1); digitalWrite(we,0); delay(2); //give the chip time digitalWrite(io[0],b0);//<-| digitalWrite(io[1],b1);// | set address values digitalWrite(io[2],b2);// | digitalWrite(io[3],b3);//<-| delay(2); //give the chip time digitalWrite(we,1); digitalWrite(od,0); }
void addrSet(int a0,int a1,int a2,int a3,int a4,int a5,int a6,int a7) //Set address on RAM { digitalWrite(addr[0],a0);//<-| digitalWrite(addr[1],a1);// | digitalWrite(addr[2],a2);// | digitalWrite(addr[3],a3);// |set address to write/read to/from digitalWrite(addr[4],a4);// | digitalWrite(addr[5],a5);// | digitalWrite(addr[6],a6);// | digitalWrite(addr[7],a7);//<-| delay(5); //give chip time }
void r() //read from I/O on RAM { pinMode(io[0],INPUT); pinMode(io[1],INPUT); pinMode(io[2],INPUT); pinMode(io[3],INPUT); delay(100); ios[0] = digitalRead(io[0]); ios[1] = digitalRead(io[1]); ios[2] = digitalRead(io[2]); ios[3] = digitalRead(io[3]); }
void serialTrans() { Serial.print("---->\n"); Serial.print(ios[0]); Serial.print(ios[1]); Serial.print(ios[2]); Serial.print(ios[3]); Serial.print("\n---->\n"); }
void setup() { Serial.begin(9600); digitalWrite(od,0); digitalWrite(we,1); }
void loop() {}
Thanks in advance.
Logged
0
Offline
Newbie
« Reply #1 on: April 20, 2011, 07:56:31 pm » |
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #2 on: April 21, 2011, 09:03:07 am » |
you use pin 0 and 1 these are also the hardware serial pins - Didn't you get problems with that? I would make the interface of the library a bit more userfriendly, the setting of the addres is horror imho, setting individual pins as param is no good programming practice  Have you read through this one? - http://www.arduino.cc/en/Hacking/LibraryTutorial ? This is how I would start (not compiled but it is the framework), you only need to implement the details of the functions: _setAddress(), _read(), _write(); succes, Rob .h #ifndef AM9111_h #define AM9111_h // // FILE: AM9111.h // AUTHOR: Rob Tillaart // PURPOSE: AM9111library for Arduino // VERSION: 0.1.00 // HISTORY: See AM9111.cpp // // LICENSE: Released to the public domain // class AM9111 { public: AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin); // constructor wit two pind int read(unsigned int address); int write(unsigned int address, uint8_t value); private: void _setAddress(unsigned int address); int _read(); int write(uint8_t value); // internal pin admin uint8_t _odp; uint8_t _wep; }; #endif
.cpp // // FILE: AM9111.cpp // AUTHOR: Rob Tillaart // VERSION: 0.1.00 // PURPOSE: AM9111library for Arduino // // HISTORY: // 0.1.00 - 2011-04-12 initial version // // LICENSE: Released to the public domain //
#include "AM9111.h"
///////////////////////////////////////// // // PUBLIC // AM9111::AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin) { _odp = outputDisablePin; _wep = writeEnablePin; }
int AM9111::read(unsigned int address) { int rv = 0; _setAddress(address); rv = _read(); return rv; }
int AM9111::write(unsigned int address, uint8_t value) { int rv = 0; _setAddress(address); rv = _write(value); return rv; }
///////////////////////////////////////// // // PRIVATE // void AM9111::_setAddress(unsigned int address) { // TODO }
int AM9111::_read() { int rv = 0; // TODO return rv; }
int AM9111::_write(uint8_t value) { int rv = 0; // TODO return rv; }
-- update -- personally I think you should use a shift register like the 74HC595 => far lesser lines to use the RAM moduleOverruled by insights of Crossroads below
« Last Edit: April 22, 2011, 01:53:46 am by robtillaart »
Logged
0
Offline
Newbie
« Reply #3 on: April 21, 2011, 07:43:42 pm » |
Thanks, I will try it.  The problem with the shift register is that i don't have one, and I'm 13, so i cant just go out and buy it.
Logged
0
Offline
Newbie
« Reply #4 on: April 21, 2011, 11:32:51 pm » |
How do i use the address with an unsigned int? because it has to control 8 pins... Sorry if I'm asking too much.
Logged
Global Moderator
Boston area, metrowest
Online
Brattain Member
Available for Design & Build services
« Reply #5 on: April 21, 2011, 11:42:00 pm » |
@farlepet, check out these shift registers http://www.dipmicro.com/store/74HC59535 cents, lowest shipping around. Order a couple.
Logged
Netherlands
Offline
Tesla Member
« Reply #6 on: April 22, 2011, 01:09:14 am » |
How do i use the address with an unsigned int? because it has to control 8 pins... Sorry if I'm asking too much. (HW advice removed) int address; for(int p=0; p<8; p++) { pinMode(p, OUTPUT); digitalWrite(p, bitRead(address, p)); // http://www.arduino.cc/en/Reference/BitRead }
Sorry if I'm asking too much. Please take my advice and spend a few days to work through the examples in the tutorials and through the reference pages. You will learn a lot there, really - http://arduino.cc/en/Reference/HomePage << start here to read & learn about most (not all) important commands - http://arduino.cc/en/Tutorial/HomePage << then these will make sense
« Last Edit: April 22, 2011, 01:55:49 am by robtillaart »
Logged
Global Moderator
Online
Brattain Member
« Reply #7 on: April 22, 2011, 01:34:59 am » |
The external RAM also needs control lines - Chip Select, Write Enable, Read Enable (or can maybe tie it low depending on the part, will change mode when WE becomes active)
HC595 does not do data both directions - if its a parallel RAM, then a part like 74A299PC (56 cents at Newark) will be better, can shift out to load the RAM, and shift in to read it.
Serial RAM has same function internally.
I need sleep ...
Logged
Netherlands
Offline
Tesla Member
« Reply #8 on: April 22, 2011, 01:52:57 am » |
@CrossRoads, You are absolutely right, the RAM need to be read also  so the 595 will only do half the trick I'll update my prev post
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #9 on: April 22, 2011, 06:53:27 am » |
The problem with the shift register is that i don't have one, and I'm 13, so i cant just go out and buy it. I can understand age restrictions on the purchase of weapons and alcohol, but shift registers? Crazy.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #10 on: April 22, 2011, 09:39:53 am » |
The problem with the shift register is that i don't have one, and I'm 13, so i cant just go out and buy it. I can understand age restrictions on the purchase of weapons and alcohol, but shift registers? Crazy. Perhaps with a permission note from his parents? Lefty
Logged
0
Offline
Newbie
« Reply #11 on: April 22, 2011, 11:53:12 am » |
OK, i got it now, I didn't know that there was a way to read specific bits from a number, i will start working on it.
And by saying that I'm 13, i meant i cant drive out and get one, i don't have a credit card, and my parents don't know much about electrical things, and they don't like to buy stuff online very much, especially if they don't know what it is. But maybe they will be OK with it with that website with the 35 cent shift register.
Logged
Global Moderator
Online
Brattain Member
« Reply #12 on: April 22, 2011, 11:55:45 am » |
dipmicro is very good, I have bought a lot of things from them.
Logged
0
Offline
Newbie
« Reply #13 on: April 22, 2011, 11:57:21 am » |
Yeah, I just wish Radio Shack had things like that, and that they were less expensive.
Logged
0
Offline
Newbie
« Reply #14 on: April 22, 2011, 12:53:00 pm » |
Thanks for the help, I just have one more error: C:\Program Files (x86)\arduino-0022\libraries\AM9111\AM9111.cpp: In member function 'int AM9111::_read()': C:\Program Files (x86)\arduino-0022\libraries\AM9111\AM9111.cpp:74: error: lvalue required as left operand of assignment and here is my code: header: #ifndef AM9111_h #define AM9111_h
#include "WProgram.h"
class AM9111 { public: AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin); // constructor wit two pind int read(unsigned int address); int write(unsigned int address, uint8_t value); int setIO(uint8_t IO0, uint8_t IO1, uint8_t IO2, uint8_t IO3);
private: void _setAddress(unsigned int address); int _read(); int _write(uint8_t value); // internal pin admin uint8_t _odp; uint8_t _wep; uint8_t _IO[]; uint8_t _rbits; }; #endif
source: #include "AM9111.h" #include "WProgram.h"
int AM9111::setIO(uint8_t IO0, uint8_t IO1, uint8_t IO2, uint8_t IO3) { _IO[0] = IO0; _IO[1] = IO1; _IO[2] = IO2; _IO[3] = IO3; }
///////////////////////////////////////// // // PRIVATE // void AM9111::_setAddress(unsigned int address) { for(int p=0; p<8; p++) { pinMode(p, OUTPUT); digitalWrite(p, bitRead(address, p)); } }
int AM9111::_read() { digitalWrite(_odp,0); digitalWrite(_wep,1); int rv = 0; bitWrite(_rbits,0,digitalRead(_IO[0])); bitWrite(_rbits,1,digitalRead(_IO[1])); bitWrite(_rbits,2,digitalRead(_IO[2])); bitWrite(_rbits,3,digitalRead(_IO[3])); _read() = _rbits; return rv; }
int AM9111::_write(uint8_t value) { digitalWrite(_odp,1); digitalWrite(_wep,0); int rv = 0; digitalWrite(_IO[0],bitRead(0,value)); digitalWrite(_IO[1],bitRead(1,value)); digitalWrite(_IO[2],bitRead(2,value)); digitalWrite(_IO[3],bitRead(3,value)); return rv; }
Program: #include <AM9111.h>
AM9111 ram(12,13);
void setup() { Serial.begin(9600); ram.setIO(8,9,10,11); ram.write(0,12); Serial.print("Read: "); Serial.print(ram.read(0)); }; void loop(){};
Logged
