Topic: Library for RAM chip (Read 7750 times) previous topic - next topic
farlepet
this is what i have, what should i change?
Code: [Select]
int AM9111::read(unsigned int address)
  int rv = 0;
  _read() = rv;
  _setAddress(address);
  return rv;
Code: [Select]
int AM9111::_read()
  int rv = 0;
  digitalWrite(_odp,0);
  digitalWrite(_wep,1);
  bitWrite(rv,0,digitalRead(_IO[0]));
  bitWrite(rv,1,digitalRead(_IO[1]));
  bitWrite(rv,2,digitalRead(_IO[2]));
  bitWrite(rv,3,digitalRead(_IO[3]));
  _read() = rv;
AWOL
#31
Apr 23, 2011, 12:20 am Last Edit: Apr 23, 2011, 12:26 am by AWOL Reason: 1
Code: [Select]
_read() = rv;
I thought we'd already decided that this was a no-no?
Code: [Select]
  int rv = 0;
  _read() = rv;
  return rv;
Is that really the correct order of events?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nickgammon
Code: [Select]
int AM9111::_read()
 int rv = 0;
 bitWrite(_rbits,0,digitalRead(_IO[0]));
 bitWrite(_rbits,1,digitalRead(_IO[1]));
 bitWrite(_rbits,2,digitalRead(_IO[2]));
 bitWrite(_rbits,3,digitalRead(_IO[3]));
 _read() = _rbits;
 return rv;
Someone's been doing too much Visual Basic. ;)
Instead of:
Code: [Select]
 _read() = _rbits;
 return rv;
You want:
Code: [Select]
 return _rbits;
Although I'm not sure what rv does. Did you put it there to make compiler errors go away?
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
int AM9111::_read()
 int rv = 0;
 _read() = _rbits;
 return rv;
I still don't totally get this. Are you trying to change _rbits? In which case why return anything from the function? In that case you want:
Code: [Select]
void AM9111::_read()
 _rbits = 0;
But if you want to return stuff, and not affect things such as _rbits (have side-effects) then you actually want:
Code: [Select]
int AM9111::_read()
 int rv = 0;
 return rv;
More info:
farlepet
farlepet
Yes! It finally compiled! I will upload it tomorrow morning and try it.
Thanks for all your help :)
And what do you mean by "Someone's been doing too much Visual Basic"?
nickgammon
Well, have you done Visual Basic?
In VB, a function returns its results by assigning to the function name. For example:
Code: [Select]
function foo (a, b)
  foo = a + b   ' return result of adding a to b
end function
So when I saw you write:
Code: [Select]
_read() = _rbits;
I thought you might have thought this was how you returned the function value.
More info:
farlepet
Well i have done a little visual basic, but not much, i did more visual c++.
and i have made an arduino sketch thad did, for example:
Code: [Select]
boolean yn(int pin)
  yn = digitalRead(pin);
nickgammon
Not one that compiled, right?
Code: [Select]
sketch_apr23c.cpp: In function 'boolean yn(int)':
sketch_apr23c:2: error: assignment of function 'boolean yn(int)'
sketch_apr23c:2: error: cannot convert 'int' to 'boolean ()(int)' in assignment
More info:
farlepet
hmm, well i know it was something like that, mabey i used if statements or something, i don't know. it was a while ago. Well ill test the lib tomorrow...
farlepet
Now the _read() always returns 0
here is the code:
Code: [Select]
#include "AM9111.h"
#include "WProgram.h"
// PUBLIC
AM9111::AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin)
  _odp = outputDisablePin;
  _wep = writeEnablePin;
int AM9111::setIO(uint8_t IO0, uint8_t IO1, uint8_t IO2, uint8_t IO3)
  _IO[0] = IO0;
  _IO[1] = IO1;
  _IO[2] = IO2;
  _IO[3] = IO3;
  int rv = 0;
  return rv;
int AM9111::write(unsigned int address, uint8_t value)
  int rv = 0;
  rv = _write(value);
  return rv;
// PRIVATE
void AM9111::_setAddress(unsigned int address)
for(int p=0; p<8; p++)
  pinMode(p, OUTPUT);
  digitalWrite(p, bitRead(address, p));
int AM9111::_read()
  int rv = 0;
  return rv;
int AM9111::_write(uint8_t value)
  digitalWrite(_odp,1);
  digitalWrite(_wep,0);
  int  rv = 0;
  digitalWrite(_IO[0],bitRead(0,value));
  digitalWrite(_IO[1],bitRead(1,value));
  digitalWrite(_IO[2],bitRead(2,value));
  digitalWrite(_IO[3],bitRead(3,value));
  return rv;
farlepet
is it because of the first read statement rv = 0?
AWOL
#42
Apr 23, 2011, 09:32 pm Last Edit: Apr 23, 2011, 09:34 pm by AWOL Reason: 1
Yes.
That, and the fact that you don't call _read from read.
farlepet
how do you call _read from read?
AWOL
In your own reply #30, you very nearly did.
You just got it the wrong way round.
