Loading...
Pages: 1 2 3 [4]   Go Down
Author Topic: Library for RAM chip  (Read 1718 times)
0
Offline Offline
Newbie
Intermediate Arduino user
View Profile
I got it to work, and i just got the Shift Registers today, so i will experiment with them and add to the library.
Logged
0
Offline Offline
Newbie
View Profile
I got the shift register working, but it wont work now, it keeps sending a zero
Code:
#include "AM9111_Shift.h"
#include "WProgram.h"
// PUBLIC
AM9111::AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin, uint8_t clockPin, uint8_t latchPin, uint8_t dataPin)
  _odp = outputDisablePin;
  _wep = writeEnablePin;
  _cp = clockPin;
  _lp = latchPin;
  _dp = dataPin;
  pinMode(_lp, OUTPUT);
  pinMode(_cp, OUTPUT);
  pinMode(_dp, OUTPUT);
int AM9111::setIO(uint8_t IO0, uint8_t IO1, uint8_t IO2, uint8_t IO3)
  _IO[0] = IO0;
  _IO[1] = IO1;
  _IO[2] = IO2;
  _IO[3] = IO3;
int AM9111::read(unsigned int address)
  int rv = 0;
  _setAddress(address);
  return rv;
int AM9111::write(unsigned int address, uint8_t value)
  int rv = 0;
  rv = _write(value);
  return rv;
// PRIVATE
void AM9111::_setAddress(unsigned int address)
for(int p=0; p<8; p++)
  digitalWrite(_lp, LOW);
    // shift out the bits:
  shiftOut(_dp, _cp, MSBFIRST, address);
    //take the latch pin high so the LEDs will light up:
  digitalWrite(_lp, HIGH);
    // pause before next value:
  delay(15);
int AM9111::_read()
  pinMode(_IO[0],INPUT);
  pinMode(_IO[1],INPUT);
  pinMode(_IO[2],INPUT);
  pinMode(_IO[3],INPUT);
  digitalWrite(_odp,0);
  digitalWrite(_wep,1);
  int rv = 0;
  bitWrite(rv,0,digitalRead(_IO[0]));
  bitWrite(rv,1,digitalRead(_IO[1]));
  bitWrite(rv,2,digitalRead(_IO[2]));
  bitWrite(rv,3,digitalRead(_IO[3]));
  return rv;
int AM9111::_write(uint8_t value)
  pinMode(_IO[0], OUTPUT);
  pinMode(_IO[1], OUTPUT);
  pinMode(_IO[2], OUTPUT);
  pinMode(_IO[3], OUTPUT);
  digitalWrite(_odp,1);
  digitalWrite(_wep,0);
  int  rv = 0;
  digitalWrite(_IO[0],bitRead(0,value));
  digitalWrite(_IO[1],bitRead(1,value));
  digitalWrite(_IO[2],bitRead(2,value));
  digitalWrite(_IO[3],bitRead(3,value));
  return rv;
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
I wonder why that is:
Code:
  int rv = 0;
  return rv;
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
For that matter:
Quote
Code:
int  rv = 0;
  return rv;
What is the purpose of rv here? It is set to zero and you never change it.
I am guessing here you are just throwing in stuff to make compiler errors go away. Well that worked, now you have runtime errors.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
For that matter:
Quote
Code:
int  rv = 0;
That's in a "write" method.
Not sure why a "write" method would want to return a value anyway.
Logged
Pages: 1 2 3 [4]   Go Up
Print
Jump to:
