Topic: Library for RAM chip (Read 7470 times) previous topic - next topic
AWOL
farlepet
AWOL
_read isn't a function returning a reference, so the assignment isn't possible.
farlepet
OK, so how would I make it so you could do a statement like: Serial.print(AM9111.read()); ?
AWOL
int AM9111::_read()
  digitalWrite(_odp,0);
  digitalWrite(_wep,1);
  int rv = 0;
  bitWrite(_rbits,0,digitalRead(_IO[0]));
  bitWrite(_rbits,1,digitalRead(_IO[1]));
  bitWrite(_rbits,2,digitalRead(_IO[2]));
  bitWrite(_rbits,3,digitalRead(_IO[3]));
  _read() = _rbits;
  return rv;
Have you ever thought why this routine would always return zero? (if it were to compile)
Is that what you want?
farlepet
WHat i wanted was to have _read read the outputs of the ram and have _read = the output ex: out = 1101; _read = 13;
AWOL
#21
Apr 22, 2011, 11:42 pm Last Edit: Apr 22, 2011, 11:45 pm by AWOL Reason: 1
If that's what you wanted, why does it return zero?
Your _write method also (unusually) returns a value that is always zero.
farlepet
I changed, but still has an error, do i have to have it do: return _rbits; ?
AWOL
Did you initialise _rbits?
farlepet
AWOL
No, apart from the missing semicolon, that looks more like a declaration, not an initialisation.
The clue is, you did initialise a variable, but it wasn't _rbits.
farlepet
so, how should i do it?
AWOL
I'd probably forget about _rbits altogether, and use (I mean really use) "rv".
farlepet
AWOL
By the way, the spelling is "indeterminate", not "intermediate".    ;-)
