Topic: Library for RAM chip (Read 8725 times) previous topic - next topic
farlepet
this is what i have, what should i change?
int AM9111::read(unsigned int address)
  int rv = 0;
  _read() = rv;
  _setAddress(address);
  return rv;
int AM9111::_read()
  int rv = 0;
  digitalWrite(_odp,0);
  digitalWrite(_wep,1);
  bitWrite(rv,0,digitalRead(_IO[0]));
  bitWrite(rv,1,digitalRead(_IO[1]));
  bitWrite(rv,2,digitalRead(_IO[2]));
  bitWrite(rv,3,digitalRead(_IO[3]));
  _read() = rv;
AWOL
#31
Apr 23, 2011, 12:20 am Last Edit: Apr 23, 2011, 12:26 am by AWOL Reason: 1
_read() = rv;
I thought we'd already decided that this was a no-no?
  int rv = 0;
  _read() = rv;
  return rv;
Is that really the correct order of events?
nickgammon
int AM9111::_read()
 int rv = 0;
 bitWrite(_rbits,0,digitalRead(_IO[0]));
 bitWrite(_rbits,1,digitalRead(_IO[1]));
 bitWrite(_rbits,2,digitalRead(_IO[2]));
 bitWrite(_rbits,3,digitalRead(_IO[3]));
 _read() = _rbits;
 return rv;
Someone's been doing too much Visual Basic. ;)
Instead of:
 _read() = _rbits;
 return rv;
You want:
 return _rbits;
Although I'm not sure what rv does. Did you put it there to make compiler errors go away?
nickgammon
int AM9111::_read()
 int rv = 0;
 _read() = _rbits;
 return rv;
I still don't totally get this. Are you trying to change _rbits? In which case why return anything from the function? In that case you want:
void AM9111::_read()
 _rbits = 0;
But if you want to return stuff, and not affect things such as _rbits (have side-effects) then you actually want:
int AM9111::_read()
 int rv = 0;
 return rv;
farlepet
farlepet
Yes! It finally compiled! I will upload it tomorrow morning and try it.
Thanks for all your help :)
And what do you mean by "Someone's been doing too much Visual Basic"?
nickgammon
Well, have you done Visual Basic?
In VB, a function returns its results by assigning to the function name. For example:
function foo (a, b)
  foo = a + b   ' return result of adding a to b
end function
So when I saw you write:
_read() = _rbits;
I thought you might have thought this was how you returned the function value.
farlepet
Well i have done a little visual basic, but not much, i did more visual c++.
and i have made an arduino sketch thad did, for example:
boolean yn(int pin)
  yn = digitalRead(pin);
nickgammon
Not one that compiled, right?
sketch_apr23c.cpp: In function 'boolean yn(int)':
sketch_apr23c:2: error: assignment of function 'boolean yn(int)'
sketch_apr23c:2: error: cannot convert 'int' to 'boolean ()(int)' in assignment
farlepet
hmm, well i know it was something like that, mabey i used if statements or something, i don't know. it was a while ago. Well ill test the lib tomorrow...
farlepet
Now the _read() always returns 0
here is the code:
#include "AM9111.h"
#include "WProgram.h"
// PUBLIC
AM9111::AM9111(uint8_t outputDisablePin, uint8_t writeEnablePin)
  _odp = outputDisablePin;
  _wep = writeEnablePin;
int AM9111::setIO(uint8_t IO0, uint8_t IO1, uint8_t IO2, uint8_t IO3)
  _IO[0] = IO0;
  _IO[1] = IO1;
  _IO[2] = IO2;
  _IO[3] = IO3;
  int rv = 0;
  return rv;
int AM9111::write(unsigned int address, uint8_t value)
  int rv = 0;
  rv = _write(value);
  return rv;
// PRIVATE
void AM9111::_setAddress(unsigned int address)
for(int p=0; p<8; p++)
  pinMode(p, OUTPUT);
  digitalWrite(p, bitRead(address, p));
int AM9111::_read()
  int rv = 0;
  return rv;
int AM9111::_write(uint8_t value)
  digitalWrite(_odp,1);
  digitalWrite(_wep,0);
  int  rv = 0;
  digitalWrite(_IO[0],bitRead(0,value));
  digitalWrite(_IO[1],bitRead(1,value));
  digitalWrite(_IO[2],bitRead(2,value));
  digitalWrite(_IO[3],bitRead(3,value));
  return rv;
farlepet
is it because of the first read statement rv = 0?
AWOL
#42
Apr 23, 2011, 09:32 pm Last Edit: Apr 23, 2011, 09:34 pm by AWOL Reason: 1
Yes.
That, and the fact that you don't call _read from read.
farlepet
how do you call _read from read?
AWOL
In your own reply #30, you very nearly did.
You just got it the wrong way round.
