Loading...
Pages: [1]   Go Down
Author Topic: piezo Midi drums  (Read 461 times)
New York City, NY
Offline Offline
Jr. Member
Arduino Rocks! Think befor you code | Thinking supercollider/clojure
View Profile
WWW
Hi all, I 've been working on a midi drum project and I am alittle stuck. The idea is to trigger one of sixteen notes (sensorID) depending on which of the sixteen piezo sensors are touched with velocity senitivity. Can anyome help me formatting the code for viewing the serial monitor. As it is now I see only unreadable characters in the monitor and might be the least of my worries. I am not sure I'm assinging the sensorID's correctly but I making progress.
Code:
/* ReadMultiplexedSensorsAndSendMIDI
 * Reads 2 8 channel Multiplexers and sends the values
//#define CONTROLpin1 1
#define drumchan           1
#define CONTROLpin2 2
#define CONTROLpin3 3
#define CONTROLpin4 4
#define ledPin 13
int piezoPin = 0;
int THRESHOLD = 100; // set minimum value that indicates a knock
int val,t;
int actualSensorValue;             // value from the analog input
// Variables:
char sensorID[16] = { 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74};
char sensorValueToSend = 0;            // Value of the sensor
// Some error chacking would be good here.
//If the values exceede 128 the will not fit in one byte.
//void sendCommand(char command, char sensorID, char value) {
//  Serial.print(command, BYTE);
//  Serial.print(sensorID, BYTE);
//  Serial.print(value, BYTE);
// Send a MIDI note-on message.  Like pressing a piano key
// channel ranges from 0-15
void noteOn(byte channel, byte sensorID, byte velocity) {
  midiMsg( (0x90 | channel), sensorID, velocity);
// Send a MIDI note-off message.  Like releasing a piano key
void noteOff(byte channel, byte sensorID, byte velocity) {
  midiMsg( (0x80 | channel), sensorID, velocity);
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
  digitalWrite(ledPin,HIGH);  // indicate we're sending MIDI data
  Serial.print(cmd, BYTE);
  Serial.print(data1, BYTE);
  Serial.print(data2, BYTE);
  digitalWrite(ledPin,LOW);
  //  set the states of the I/O pins:
  pinMode(ledPin, OUTPUT);
  //pinMode(CONTROLpin1, OUTPUT);
  pinMode(CONTROLpin2, OUTPUT);
  pinMode(CONTROLpin3, OUTPUT);
  pinMode(CONTROLpin4, OUTPUT);
  Serial.begin(31250);
  int i;
  int j;
  for (i=0; i <8; i++) {
    // set control pins on the multiplexers
    digitalWrite(CONTROLpin3 (i&4)>>2);//bit3
    digitalWrite(CONTROLpin2 (i&2)>>1);//bit2
    digitalWrite(CONTROLpin1 (i&1)   );//bit1
    // read the analogue inputs and send the values of the sensors.
    for(j=0; j<2; j++){
      //actualSensorValue = analogRead(j)>>3:
      // You will have to adjust this line so that can send the
      // sensor value in one byte.
      //sensorValueToSend = actualSensorValue / 7;
      //sendCommand(0x90, i+8*j, sensorValueToSend);
////temp////
 // deal with piezos, this is kind of a hack
  val = analogRead(j);
  if( val >= THRESHOLD ) {
    digitalWrite(ledPin, HIGH);
    t=0;
    while(analogRead(j) >= THRESHOLD/2) {
      t++;
    noteOn(drumchan,sensorID[i], t*2);
    delay(t);
    digitalWrite(ledPin, LOW);
    noteOff(drumchan,sensorID[i],0);
////endtemp////
    // if you uncomment this line you can check the control pins
    // of the multiplexers with your multimeter.
    //delay(500);
By viewing in the monitor I mean byte channe, btye senorID, byte, velocity.
Thanks again
Pitchoilcan
« Last Edit: April 21, 2011, 04:30:28 pm by Pitchoilcan » Logged
'if' "smells like God's vagina;"
http://twit.tv/floss61
Think different
Think UbuntuStudio
THE BEST PODCAST IN THE UNIVERSE!
http://www.noagendashow.com/
http://www.dvorak.org/na/
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Change "BYTE" to "HEX" to see the data in hexadecimal or "DEC" to see it in decimal.
Logged
Pages: [1]   Go Up
Print
Jump to:
