Topic: LM35 Temperature Sensor Giving Inverted Readings (Read 243 times) previous topic - next topic
gutyex
I have an LM35DZ sensor connected to an Arduino MEGA.
When I warm up the sensor, the value given by AnalogRead goes down, and when I cool down the sensor the value goes up.
With the sensor connected directly to +5V, Pin0, and GND I was getting very noisy values. After reading other posts and experimenting, I found that putting a resistor & capacitor in series between Vout and GND stabilised the readings (Values 500Ω & 0.01uF as that's what I had on hand)
The sensor & other components are on a breadboard, connected to the Arduino by short (less than 10CM) wires.
The Arduino is powered by a 12V supply, though USB is still connected for the serial output.
I thought it might be an issue with my code, so I reduced it down to the simplest possible based on https://playground.arduino.cc/Main/LM35HigherResolution and I'm still getting the same results
Code: [Select]
int reading;
int tempPin = 0;
    analogReference(INTERNAL1V1); //ArduinoMEGA Internal 1.1V reference
    reading = analogRead(tempPin);
    Serial.println(reading);
alesam
Could you provide an schematic diagram showing how you connected the sensor to arduino?
outsider
Be sure you have the LM35 pins connected correctly, here's a datasheet.
https://www.futurlec.com/Linear/LM35DZ.shtml
Code: [Select]
float reading;
int tempPin = 0;
    reading = analogRead(tempPin) * 1.1 / 1024 * 100;
    Serial.println(reading,1);
MarkT
gutyex
@alesam see attached (sorry for the bad MSpaint drawing, I don't have access to anything better right now)
@outsider I've checked the pins, definitely wired correctly according to the datasheet.
@MarkT They came from a chinese seller on eBay, how would I check if they're genuine or not?
outsider
#5
Jan 17, 2019, 05:18 pm Last Edit: Jan 17, 2019, 05:48 pm by outsider
Looking at the flat side with pins pointed down, they should be (left to right) V+, Vout, V-, is that what you have?
gutyex
Yep
MarkT
Compare printing with a genuine part, the font and layout may differ somewhat.
You cannot be sure about any parts from eBay, although they may be fine, sometimes they are not.
gutyex
#8
Jan 20, 2019, 03:47 pm Last Edit: Jan 20, 2019, 05:52 pm by gutyex
They look the same as all the photos that google images returns for "LM35DZ", but if I connect them directly to 5V and GND on the arduino then measure the voltage between Vout & GND with the my multimeter I get less than 10mV regardless of temperature, so I'm inclined towards them being fakes or a bad batch. I've ordered some more from a different seller so I'll see how those work out.
