Topic: USB shield to MTi-G 28A53G35 IMU (Read 698 times) previous topic - next topic
penderam
I have a USB Shield, sparkfun DEV- 09947. I have an Arduino Uno. I have managed to successfully connect my shield but now wish to get information off of the IMU. The IMU has a USB connector in which it can connect to a PC by using MT Manager.
I am curious, is there anything in the USB Host Library 2.0 that would assist in collecting data off of this IMU, I haven't found anything yet? I essentially just need to write to it for configuration, receive data and place it in a buffer, and then parse it. Xsens gives some custom code, but I do not know how difficult it would be to talk through the shield without the library.
Any help would be appreciated!
pylon
If you want to read an IMU with an Arduino I strongly suggest you use an IMU with an I2C or SPI interface. Although you can connect your PC IMU to the USB Host shield you probably won't get a driver for it and writing one yourself is not as straight-forward as you might think.
If you provide a link to that IMU you're using we might suggest you some alternatives or alternative ways to access your's.
penderam
I will eventually be using such an IMU, but it was requested I make it work first with this IMU, they said they wish to calibrate the other IMU off of this one. I believe that this IMU also has a rs-232 connector that can be attached. That might be a much better option. That combined with a level shifter for the TTL voltages.
Here is the link: https://www.xsens.com/products/mti-g/
We unfortunately already bought the shield, although I have not yet soldered it on as I wanted it working before I did. I know USB protocol is difficult and was hoping for something in the USB Host Library 2.0 that would assist, but it seems that all the functionality is very specific. This might be to much of a niche request.
gbafamily
To connect to an AVR processor you want 5V TTL signals. Sounds like you do not want the USB or the RS-232 converters on the IMU. But you might need 3.3V <-> 5V logic level shifters. The datasheet should explain the logic levels for the IMU.
If you want to do it the hard way using USB, look at the USB host library for the USB to serial drivers it supports. I think FTDI, PL2303, and CDC ACM are supported. If your USB serial converter uses a different chip, you will have write a driver for it which is difficult.
penderam
Hey gbafamily, there is only three options the connection coming out of the IMU. There is USB, the hard option as you put it. There is a Rs-232 I could buy. OR I can do a little splicing. The information coming out of the IMU is serial and is in the form of 8 wires, those 8 wires going into a board with a few chips that transfers it into USB(Power, Ground D+, D-).
I do already have a 3.3-5.0 converter.
If the USB Host Library does have drivers, wouldn't that become the easier option once again?
gbafamily
Quote
Yes and it would be safer. Probing around the header pins without proper documentation may destroy the device. The IMU looks like it is much more expensive than the usual hobby grade junk.
pylon
Quote
You don't need a level shifter but a driver chip. As that device also supports RS-485 I would use that interface and add a corresponding driver board to the Arduino.
Quote
This is not what we usually think about when someone writes about an IMU. That's more a GPS receiver.
Quote
If you're not very experienced with USB development I would recommend against writing your own driver. As the linked page says that the USB interface is just an external converter to one of the other interface variants you might be lucky that they used a familiar chip such as the FTDi232R in which case the host shield software already supports it.
penderam
Quote
You are correct that it has that capability, but it also can be used as just another IMU with calibrated or raw data. Either way it is overkill, and is over complicating this task to some extent.
Quote
I looked into the hardware guide and found that it is indeed using a FT232. So I am attempting to use the send and receive commands that was given in the USBFTDIloopback code. I am having difficulty and am wondering if there are better examples out there or people I can ask how to correctly send and take in data.
I am able to receive and send but am not receiving what I should be based upon the low level communication guide from xsens. So the data I may be sending might not being sent correctly to configure the IMU. I looked on this forum for the USB host library 2.0, and it seems like the creator used to be very involved in answering but no longer.
gbafamily
Posting examples of the expected values versus the received values might be helpful.
The USB host library github.com repo is where the real experts are. Check the issues first before posting. Your question may have already been asked and answered.
penderam
I also think I might just be having a disconnect on how to use the Ftdi.SndData and the Ftdi.RcvData functions. The example isn't working correctly that they give, I just continually get "." after I run it.
 I assumed this was because my IMU requires specific arrays of bytes to be sent to it for it to start outputting data correctly, and doesn't just start outputting data. After messing with it, I received nothing but zeros, which were not expected.
The low level communication protocol is attached. I am essentially trying to send and receive the byte arrays in the picture.
I have found only two or so people on the forum or github that also have been trying to use the FTDI USB too Serial library. Seems rarer then I expected it to be, and neither example have been helpful.
gbafamily
Plug the device into a computer and see what comes out. You may have to install an FTDI driver. Also you need a program that dumps serial data in HEX. Ubuntu Linux (and maybe other distros) come with FTDI drivers pre-installed. Install a program named cutecom (sudo apt install cutecom). cutecom is a terminal program but it works in binary/HEX. Very handy for troubleshooting serial devices with binary protocols. Or write a program in some easy scripting language  such as Python to read/write the serial port.
If other attempts have been made to configure the device, it may be stuck at a baud rate other than 115200. See if the device has a factory reset button. The last resort is to try every available baud rate until some reasonable data comes  out.
The sketch you posted is not very useful because it sends an invalid command "DEADBEEF" that might confuse the device. I suggest not sending anything and just see what comes back. The device is supposed to send measurements if it does not receive any commands. The protocol is in binary so print HEX.
Something like this might show measurements.
Code: [Select]
Usb.Task();
if( Usb.getUsbTaskState() == USB_STATE_RUNNING )
uint8_t buf[64];
uint16_t rcvd = sizeof(buf);
uint8_t rcode = Ftdi.RcvData(&rcvd, buf);
if (rcode && rcode != hrNAK)
ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
// The device reserves the first two bytes of data
//   to contain the current values of the modem and line status registers.
for (uint8_t i = 2; i < rcvd; i++) {
// Show data in HEX
Serial.print(buf[i], HEX);
Serial.print(' ');
penderam
Quote
Luckily the IMU comes with a "Manager" MT Manager. It lets me see the output from the IMU on a GUI interface. It also lets me change the configuration without having to do it manually by sending bytes. So you may be right in saying that I might just be able to listen, once configured correctly in the manager.
Another aspect of the manager is the ability to send arrays of bytes, like I am attempting to do over the arduino. I am attempting to send and the receive. It works on the PC. I know that the chip is a FT232, so the drivers should work.
Quote
Per the documentation the baud rate is automatically set at 115200 unless I change it. I also placed it there in the manager. I did try the other baud rates, and received nothing.
Quote
I understand, that was not my attempt. That was the starting example given by the creators of the library. Was simply giving it so you could see the functions he implemented and maybe knew how to correctly use them, since its possible I am just using them incorrectly.
Unfortunately your code did now work even after configuring the IMU to output in the MT manager. I feel like either I am having a huge mishap with using the drivers correctly, or what I am doing is not possible with my current library.
penderam
#12
Jan 23, 2019, 09:56 pm Last Edit: Jan 23, 2019, 09:57 pm by penderam
If someone knew enough to simply explain the functions that would be enough for me to realize If I am using them correctly or not, and then to move on to another option if they are simply not working. Any help would be greatly appreciated, on top of the help you guys have already given me.
Thanks!
gbafamily
It is possible the USB host shield is not working which seems to happen a lot based on messages on this board. If you see "OSC did not start" message, the shield is not working. You might have to try the RS232 converter.
Do not post code you are not actually using. Post the code you have tried with the IMU.
SndData first parameter is the number of bytes to send. The second is a point to an array of uint8_t to send. The example uses a NULL terminated string instead.
uint8_t command[]={0xFA, 0xFF};
rcode = Ftdi.SndData(sizeof(command), command);
penderam
Quote
The board works correctly. I have tested other functions, such as the MIDmouse and MIDkeyboard. I can also gather information off of the IMU through USB-desc and board_qc. Both our functions meant to check connection and gather information on the device.
Sorry about that this is some code I have tried.
Quote
What does this portion of the code do?
If I leave the if statements open and allow the for loops to be inside them, the if statements never occur and the loops don't run. If I close the if statements make them separate, loops run and I do not get "...."(stuck in the first if statement) but the buf variable is never assigned anything other than zero, so I am receiving nothing. Obviously this if statement is important, but it is never true.
