Topic: 441 water drops (Read 11169 times) previous topic - next topic
pelang
Machine that adds drops of water onto a special textured surface. Each drop forms into an almost perfect sphere through the surface tension of the water and the omniphopic Material. The electronically controlled pipette wanders through a square grid of 21 x 21 drops to form a micro-matrix and returns to the beginning. After approximately 300 minutes, and when thewater drops have evaporated, the same process starts again.
http://pelang.ch/video/falling_objects_positioning_systems.mov
mowcius
umm, wow - trying to think of some practical use but failing - cool though :D
biocow
Use food coloring in water and draw dot-matrix style pictures. Or sphere-matrix in this case.
Very cool non the less.
Onions
Very impressive! Adding to what biocow said, if you put a light underneath it you could project an interesting picture onto the ceiling, although that would mean using something clear underneath the droplets, rather than the omniphopic material, so it might not work...
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
frikosal
Really nice !
Can you give us some details about the positioning system ?
mowcius
Yeah I'd be interested in that too :)
pelang
thanks,
well there is not much to say. Arduino control's the stepperdriver, step's and direction. Linearaxis are THK (secandhand). Little relay to trigger the dispenser.
the code is kind of mess... was last minut project..
Code: [Select]
Falling objects - positioning systems
is an machine that adds drops of water onto a special textured surface.
After approximately 300 minutes, and when the water drops have evaporated, the same process starts again.
http://pelang.ch/
int dirpin1 = 11; //Stepper 1, Direction
int steppin1 = 12; //Stepper 1, Steps
int dirpin2 = 9; //Stepper 2, Direction
int steppin2 = 10; //Stepper 2, Steps
int enableX = 5; // Enable driver X
int enableY = 4; // Enable driver Y
int relay = 8; //Relay
int Xdrops = 20; //numbers of x drops
int Pause = 100; // Pause wenn Drops
int PauseDrop = 50; //whait befor drop
int limitX = 7; // limitswitch X achse
int limitY = 6; // limitswitch X achse
int switchstateX = 0;
int switchstateY = 0;
int Xsize = 300;  //distance from each drop
int Ysize = 3000; //distance from each drop
  pinMode(steppin1, OUTPUT);
  pinMode(dirpin1, OUTPUT);
  pinMode(steppin2, OUTPUT);
  pinMode(dirpin2, OUTPUT);
  pinMode(enableX, OUTPUT);
  pinMode(enableY, OUTPUT);
  pinMode(relay, OUTPUT);
  pinMode(limitX, INPUT);
  pinMode(limitY, INPUT);
digitalWrite(enableX, HIGH); //Schaltet X Diver ON
digitalWrite(enableY, HIGH); //Schaltet X Diver ON
/* this is for limitng the xy at the very beginning */
// limiting X
  int b;
  digitalWrite(dirpin1, LOW); // Set X the direction.
  for (b = 0; b<10000; b++)
        switchstateX = digitalRead(limitX);
        if (switchstateX == HIGH)
        digitalWrite(steppin1, HIGH);
        digitalWrite(steppin1, LOW);
        delayMicroseconds(800);
   digitalWrite(dirpin1, HIGH); // Set X the direction.
   for (b = 0; b<7800; b++)
// limiting Y
  long g;
  digitalWrite(dirpin2, HIGH); // Set X the direction.
  for (g = 0; g<100000; g++)
        switchstateY = digitalRead(limitY);
        if (switchstateY == HIGH)
        digitalWrite(steppin2, HIGH);
        digitalWrite(steppin2, LOW);
        delayMicroseconds(300);
   digitalWrite(dirpin2, LOW); // Set X the direction.
   for (g = 0; g<68000; g++)
int i;
int k;
int b;
int m;
long r;
for (m = 0; m<10; m++) // Make 5 Lines of 5 Drops
   digitalWrite(dirpin2, HIGH); // Set Y the direction.
// move Y 1 line
     for (b = 0; b<Ysize; b++)
        delayMicroseconds(1200);
// make drops
      delay(PauseDrop); //whait befor drop
      digitalWrite(relay, HIGH);   // turn Relay on
      delay(Pause);              // wait for a second
      digitalWrite(relay, LOW);    // turn Relay off
// move X 10 times forward
     for (i = 0; i<Xdrops; i++) // Make N Drops forward X
       for (k = 0; k<Xsize; k++)  // Make 80 Steps = 1mm
                                                        //  Moving X Axis 10 Steps CW
// make drops
// move Y 1 line
// make drop
// change direction of X
      digitalWrite(dirpin1, HIGH); // Set the direction.
// move X 10 times backwards
// make drops
// last line last line last line last line last line
// move Y 1 line
// make drop
      digitalWrite(dirpin1, LOW); // Set the direction.
// make drops
// Home xy
  digitalWrite(dirpin2, LOW); // Set Y the direction.
   for (r = 0; r<(Xsize * Xdrops); r++) // X go back to beginng
    digitalWrite(steppin1, HIGH);   // For test with LED on
    digitalWrite(steppin1, LOW);    // For test with LED off
    delayMicroseconds(1200);              // wait for a second
    for (r = 0; r<66000; r++) // Y go back to beginng
    digitalWrite(steppin2, HIGH);   // For test with LED on
    digitalWrite(steppin2, LOW);    // For test with LED off
    delayMicroseconds(400);              // wait for a second
digitalWrite(enableX, LOW); //Schaltet X Diver OFF
digitalWrite(enableY, LOW); //Schaltet X Diver OFF
delay(5000); // verdunsten
robtillaart
Quote
What happens if you freeze it ?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
mowcius
Quote
The water?
I just had a load of ideas run through my head about creating micro-ice spheres ;)
wildbill
Very cool - I love those little spheres. What instigated the project?
pelang
#10
Apr 29, 2011, 04:34 am Last Edit: Apr 29, 2011, 04:36 am by pe lang Reason: 1
it was for a group exhibition here in berlin with the titel: decay.
i actualy built a cnc router, during that i found it more fun to test the program routines with water drops
thanks all, also for the help (for my projects) i got here !
biocow
Looks like you're hitting he blogs.
http://gizmodo.com/5808901/441-perfectly-sphere-water-droplets-aligned-to-a-grid
mowcius
Haha some of those comments :D
focalist
I refuse to look up the definition because it will remove the much more entertaining mental image:
What exactly is an "Omniphobic Material"?
'Today we saw a demonstration of Freakoutium, the metal that our patented Panic-O-Meter operates on.  The United States Department of Homeland Security has expressed interest.'
mowcius
Omniphobic materials - presumably don't like anything - repel most things
Hydrophobic materials repel water so I presume it's hydrophobic as well as other things.
This means the water beads on the surface rather than spreading out (like a heavily waxed car roof)
