Topic: Difficulties with the virtual wire library and 433RF (Read 4311 times) previous topic - next topic
Targettio
I have bought a 433Mhz transmitter and receiver and want to use them to get 2 arduinos to communicate.
http://www.farnell.com/datasheets/54125.pdf
http://www.farnell.com/datasheets/54130.pdf
I have connected them to the arduino as shown in the pdfs (double checked) and tried to run the examples included in the library:
Transmitter
Code: [Select]
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
    Serial.begin(9600);   // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000); // Bits per sec
    const char *msg = "hello";
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);
    delay(200);
Receiver
Code: [Select]
// receiver.pde
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// $Id: receiver.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
        digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
    Serial.print(buf[i], HEX);
    Serial.print(" ");
Serial.println("");
The transmitter sits an happy blinks led13 all day long, but I never receive a message on the receiver. I am starting to think that the transmitter and receiver aren't suitable to work together. Can any one help?
Thanks in advance
nickgammon
I don't see where you are setting pin 13 to an output (in either sketch).
Also, is this line needed?
Code: [Select]
The module doesn't specifically say it is a DR3100.
Do they both have 433 stamped on the crystal?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
CrossRoads
You're not trying to run both on the same arduino are you? I have not seen anyone get that to work.   You need to have them running on separate arduinos.
You have 17cm antenna wire on both?
Targettio
2 separate UNOs with two separate breadboards.
Second and fifth lines in the loop() turn led 13 on and off as info is transmitted.
I do have
Code: [Select]
commented out in the examples I have been using, but I just copy/pasted from the example so it is missing here.
The transmitter has R433A on the crystal but a big sticker saying A434. The receiver doesn't have a frequency on the crystal, just "N6.722 AC20PB". Both the receiver and transmitter are available in 315 and 433Mhz, I should have got the 433 versions of both (at least that's what my receipt says).
They both have a ~10cm piece of wire for an antenna, and the bread boards are physically touching, so there is probably less than 3 inches between the two units.
nickgammon
Targettio
#5
Apr 24, 2011, 12:33 pm Last Edit: Apr 24, 2011, 12:36 pm by Targettio Reason: 1
Oh, I see what your trying to say...
I can add a pinmode but I am not sure how that will help as LED 13 is just there for a visual representation of a transmission, which it is doing.
nickgammon
How does it blink, if it isn't defined as an output? And how do you know you didn't get a message on the receiver?
Targettio
The reciever is connected to my PC via a USB cable and it should report the recieved message in the serial monitor, but it just say "Setup" but no message.
And I guess pin 13 is defaults as an output(?). I have added a pinmode to the setup and it doesnt make any difference (i.e. it flashes either way).
nickgammon
It doesn't default as an output. I tried this sketch:
Code: [Select]
void setup ()
  digitalWrite (13, HIGH);
}  // end of setup
void loop () {}
I must admit that pin 13 glows very faintly, but that is because the pull-up resistor has been enabled. You should add:
Code: [Select]
pinMode (13, OUTPUT);
... to setup to see it more clearly.
As for your problem, checking the pdf file about VirtualWire, he seems to be talking about a transmitter (TX-C1), a receiver (RX-B1) and a transceiver (DR3100).
Now you said:
Quote
I have bought a 433Mhz transmitter and receiver ...
Not the transceiver, right?
But you have in your code:
Code: [Select]
But you don't have that part.
