Topic: arduino + LCD fades until other applications are done. (Read 840 times) previous topic - next topic
faytoceanz3
Apr 22, 2011, 08:41 pm Last Edit: Apr 22, 2011, 08:57 pm by faytoceanz3 Reason: 1
We have a LCD display and 4 switches to turn on relays for certain applications.  I'm using atmega1280 and the problem that we have in our project is that the LCD display would fade every time the switches were powered.  Once the switches are off, LCD display goes back to normal.
Another problem is that when the switches are pressed, the response is slower unless it is firmly pressed.
Is it because there is not enough voltage is supplied with everything ? Or a current problem?
I am powering the arduino through USB cable btw, which is normally 5 volts I think.
How can I solve this issue?
Will using a higher external power supply (9-12V) solve this problem?
weirdo557
do you have a part number for the relays? and can you post a quick diagram of how its connected.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
