Offline
Jr. Member
« on: April 22, 2011, 03:02:40 pm » |
Hello, i build a small 8 step sequencer, how can I get it to work with real BPM? right now I have a default delay of 50ms between each step, and another 50ms for LED blink.
If my math is right it should be 7500ms for each step to get 60 BPM. is that right?
I also have a button to increase the delay by 50ms. Is there a usual way to do this?
thnx
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #1 on: April 22, 2011, 04:12:09 pm » |
If my math is right it should be 7500ms for each step to get 60 BPM. is that right? I don't think so. 7500mS is 7.5 seconds so in 60 seconds you get 8 BPM (beats per minute) For 60 BPM you need one beat every second or 1000mS.
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #2 on: April 22, 2011, 07:12:30 pm » |
Use a Timer, much better timing. Here's my code for the timer. void timerStart() { TCCR1A = TCCR1B = 0; bitWrite(TCCR1B, CS11, 1); bitWrite(TCCR1B, WGM12, 1); timerSetFrequency(); bitWrite(TIMSK1, OCIE1A, 1); }
void timerSetFrequency() { // Calculates the Frequency for the Timer, used by the PPQ clock (Pulses Per Quarter Note) // // This uses the 16-bit Timer1, unused by the Arduino, unless you use the analogWrite or Tone functions // #define frequency (((midiClockBPM)*(PPQ))/60) OCR1A = (F_CPU/ 8) / frequency - 1; }
void timerStop(void) { bitWrite(TIMSK1, OCIE1A, 0); TCCR1A = TCCR1B = OCR1A = 0; }
ISR(TIMER1_COMPA_vect) { // here's your clock code }
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #3 on: April 22, 2011, 07:14:59 pm » |
BTW: on my code for Beat707 I use less PPQ, so I just use a counter variable to check when a step is due or not. I like to keep things at 96 PPQ for the midi clock shuffle. I can get you more details over this after tomorrow if you want me to. ;-)
Wk
Logged
Offline
Jr. Member
« Reply #4 on: April 25, 2011, 04:16:22 am » |
Hello,
thnx for that code, i still dont understand a thing of that, but I will take my time to do so. I seens some videso of your sequencer, very nice project.
solved: Right now(after i included a play button) I have the problem that the sequence changes tempo each time, one fast one slower. Would this be gone if I could include your code? (it was the switch i was using, this happens only if the circuit ist closed)
« Last Edit: April 25, 2011, 04:40:01 am by Rupertt »
Logged
Offline
Jr. Member
« Reply #5 on: April 26, 2011, 12:51:02 pm » |
could you give me an example how I can use the above code to act as a timer and set the main frequncy to 120BPM on 8 steps?
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #6 on: April 26, 2011, 01:06:17 pm » |
Will do, give me 15 minutes... ;-)
Wk
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #7 on: April 26, 2011, 01:31:56 pm » |
Created by Beat707 (c) 2011 - http://www.Beat707.com 8 Step Mini MIDI Sequencer (4 tracks)
uint8_t midiClockBPM = 120; // Max 255 uint8_t midiClockPPQCounter = 0; uint8_t midiClockSteps[4] = { B10001000, B00001000, B11111111, B00100010 }; uint8_t midiClockStepsNote[4] = { 36, 38, 42, 46 }; // Kick, Snare, HiHatClosed, HiHatOpen uint8_t midiClockCurStep = 0; uint8_t midiChannel = 9; #define PPQ 96
// ======================================================================================= // void setup() { pinMode(17,OUTPUT); digitalWrite(17,LOW); // For the Beat707 Hardware - Midi Enable // Serial.begin(31250); sendMidiAllNotesOff(); midiClockBPM = 120; midiClockPPQCounter = midiClockCurStep = 0; timerStart(); }
// ======================================================================================= // void loop() { // }
// ======================================================================================= // void timerStart() { TCCR1A = TCCR1B = 0; bitWrite(TCCR1B, CS11, 1); bitWrite(TCCR1B, WGM12, 1); timerSetFrequency(); bitWrite(TIMSK1, OCIE1A, 1); }
// ======================================================================================= // void timerSetFrequency() { #define frequency (((midiClockBPM)*(PPQ))/60) OCR1A = (F_CPU/8) / frequency - 1; }
// ======================================================================================= // void timerStop(void) { bitWrite(TIMSK1, OCIE1A, 0); TCCR1A = TCCR1B = OCR1A = 0; }
// ======================================================================================= // ISR(TIMER1_COMPA_vect) { midiClockPPQCounter++; if (midiClockPPQCounter >= 24) { midiClockPPQCounter = 0; for (uint8_t x=0; x<4; x++) { if (bitRead(midiClockSteps[x],midiClockCurStep)) { sendMidiNoteOff(midiClockStepsNote[x]); // Stop Previous Note // sendMidiNoteOn(midiClockStepsNote[x], 127); } } midiClockCurStep++; if (midiClockCurStep >= 8) midiClockCurStep = 0; } }
// ======================================================================================= // void sendMidiNoteOn(char note, char velocity) { Serial.write(0x90+midiChannel); Serial.write(note); Serial.write(velocity); }
// ======================================================================================= // void sendMidiNoteOff(char note) { Serial.write(0x80+midiChannel); Serial.write(note); Serial.write((byte)0x00); }
// ======================================================================================= // void sendMidiAllNotesOff() { Serial.write(0xB0+midiChannel); Serial.write(0x7B); Serial.write((byte)0x00); } Have Fun!
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #8 on: April 26, 2011, 01:33:54 pm » |
Now, just add some code to change midiClockSteps[] in real-time to edit the steps for each of the 4 tracks. And its easy to add more tracks if you want to.  Wk
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #9 on: April 27, 2011, 02:38:38 pm » |
Now, there's an important thing I forgot to mention... you can't use millis() or delay() at all. Use the following code instead, otherwise midi-timing will be bad... // The Following is to implement millis() and delay() without messing up with the midi clock interrupt calls // extern volatile unsigned long timer0_millis; unsigned long millisNI(void) { return timer0_millis; } void delayNI(unsigned long ms) { unsigned long endtime; endtime = timer0_millis + ms; while (((long)endtime - (long)timer0_millis) > 0) { ; } }
Logged
Offline
Jr. Member
« Reply #10 on: May 01, 2011, 10:56:02 am » |
Hello, i integrated your code, but i still dont get how to set the steps/delay inside my code: this is one of my steps, you can see the the " delay(currentTime);" defines the time until the next step is called. if(x==0){ //channel 1 if (currentSwitchState1 == 1) { AnalogValue1 = analogRead(0); note1 = AnalogValue1/8; noteOn(0xB0, 0x7B, 0x00); noteOn(0x90, note1, 0x7F); //einstellen wie lange der sound ausklingt // 81 2B 4D digitalWrite(LEDpin1, HIGH); delay(50); digitalWrite(LEDpin1, LOW); delay(currentTime); } else { delay(currentTime); } } sorry, but i come from the web programming and have only little experience in microcontroller and C programming. cheers
Logged
Offline
Jr. Member
« Reply #11 on: May 01, 2011, 10:57:45 am » |
Hello, i integrated your code, but i still dont get how to set the steps/delay inside my code: this is one of my steps, you can see the the " delay(currentTime);" defines the time until the next step is called. if(x==0){ //channel 1 if (currentSwitchState1 == 1) { AnalogValue1 = analogRead(0); note1 = AnalogValue1/8; noteOn(0xB0, 0x7B, 0x00); noteOn(0x90, note1, 0x7F); //einstellen wie lange der sound ausklingt // 81 2B 4D digitalWrite(LEDpin1, HIGH); delay(50); digitalWrite(LEDpin1, LOW); delay(currentTime); } else { delay(currentTime); } } this is how i increase/decrease my delay: currentTimeState = digitalRead(timePin1); if (currentTimeState == 1) { currentTime = currentTime + 50; }
currentTimeStateDown = digitalRead(timePin2); if (currentTimeStateDown == 1) { if (currentTime <= 50) { currentTime = 100; } else { currentTime = currentTime - 50; } } sorry, but i come from the web programming and have only little experience in microcontroller and C programming. cheers
Logged
Offline
Jr. Member
« Reply #12 on: May 22, 2011, 09:27:15 am » |
Hello,
i tried to exchange my delay with your delayNI. sadly the sequencer doenst start at all, it doesnt even start when I just enter your function and use the normal delay.
Did you realize your project alone or did you have help? Im thinking about joining someone, i have good iedas, but my C programming lacks a bit
Logged
Brazil
Offline
God Member
Wusik Dot Com
« Reply #13 on: May 22, 2011, 09:30:04 am » |
Maybe try posting the entire code so we can all take a look at it? ;-)
Wk
Logged
Offline
Jr. Member
« Reply #14 on: May 22, 2011, 09:47:56 am » |
thats all i got  The code was to long to post, so I attached the source file. Still have so many ideas for this project, but one step after another (nice in this context)
Logged
