:)Hello, I wonder if someone could help me change this piece of code to read a value of 0-99 from the pot on two 7-segment displays. Here is the sketch
// Digital pins connected to 74HC595
int latchPin = 8; // pin 12 on the 74hc595
int clockPin = 12; // pin 11 on the 74hc595
int dataPin = 11; // pin 14 on the 74hc595
// Analog input pin
int potPin = 0;
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
const byte ledCharSet[128] = {
// 00-0F: Hex digits
B01111110, B00110000, B01101101, B01111001, // 0123
B00110011, B01011011, B01011111, B01110000, // 4567
B01111111, B01111011, B01110111, B00011111, // 89AB
B01001110, B00111101, B01001111, B01000111, // CDEF
// 10-1F: Figure-8 drawing (8-character cycle)
B01000000, B00100000, B00000001, B00000100, // 1-segment
B00001000, B00010000, B00000001, B00000010,
B01100000, B00100001, B00000101, B00001100, // 2-segment
B00011000, B00010001, B00000011, B01000010,
// 20-2F: Punctuation (barely recognizable!)
B00000000, B10100000, B00100010, B00111111, // !"#
B01011010, B01001001, B00000111, B00000010, // $%&'
B01001110, B01111000, B01100011, B00110001, // ()*+
B00010000, B00000001, B10000000, B00100101, // ,-./
// 30-3F: Decimal digits (alternate) and more punctuation
B00110011, B01011011, B00011111, B01110010, // 4567
B01111111, B01110011, B01001000, B01010000, // 89:;
B00001101, B00001001, B00011001, B11100000, // <=>?
// 40-5F: Capital letters and punctuation
B01101110, B01110111, B00011111, B01001110, // @ABC
B01111100, B01001111, B01000111, B01011110, // DEFG
B00110111, B00000110, B00111100, B01010111, // HIJK
B00001110, B01110110, B00010101, B01111110, // LMNO
B01100111, B01110011, B01000110, B01011011, // PQRS
B01110000, B00111110, B00111110, B00101011, // TUVW
B01110101, B00111011, B01101101, B01001110, // XYZ[
B00010011, B01111000, B01100010, B00001000, // \]^_
// 60-7F: Lowercase letters and punctuation
B01100000, B01111101, B00011111, B00001101, // `abc
B00111101, B01101111, B01000111, B01111011, // defg
B00010111, B00010000, B00011000, B00101111, // hijk
B00001100, B01010101, B01101010, B00011101, // lmno
B01100111, B01110011, B00000101, B00010011, // pqrs
B00001111, B00011100, B00100011, B01011101, // tuvw
B01101100, B00111011, B00100101, B01000011, // xyz{
B00110110, B01100001, B01000000, B11111111 // |}~
int i, j;
// Read the value from the sensor and convert to 7-bit value
i = analogRead(potPin) >> 3;
digitalWrite(latchPin, 0);
shiftOut(dataPin, clockPin, MSBFIRST, ledCharSet[i]);
digitalWrite(latchPin, 1);
I haven't used two 595's together before and so I'm not sure how the code has to change to incorporate them. Any help appreciated
