Manchester (England England)
Online
Brattain Member
Solder is electric glue
« Reply #15 on: April 23, 2011, 01:21:51 pm » |
For the code that I have it only works this way...if(j= map(analogRead (0), 0, 1023, 0, 10)); Then you don't understand how a program works. Please re read the page on the if statement and then re write your code. At your delicate state of knowledge NEVER use a single = inside an if statement. If you require that statement then perform it outside the if statement and use the if statement properly.
Logged
Ireland
Offline
Full Member
Arduino rocks
« Reply #16 on: April 23, 2011, 01:27:29 pm » |
Extremely delicate!!!!
Logged
Ireland
Offline
Full Member
Arduino rocks
« Reply #17 on: April 30, 2011, 07:27:18 am » |
 Hello there. This is the result of my understand so far on using the "if" statement..... if ((i==2) && (h==2)){ mapMode == 11; syncPhaseInc = mapPentatonic11(analogRead(SYNC_CONTROL)); } it's working for me. And yes I managed to get three 7-segment displays working together. Two with one pot to select a musical scale (0-99 "i") and a separate one to select the key of that scale (A-G "h"). In case anyone has a need for something similar here it is (three 7-segment common cathode displays using three 595's).
int dataPin = 11; int clockPin = 12; int latchPin = 8;
byte dataRED; byte dataArrayRED[10]; byte dataArray2[7];
void setup() { pinMode(latchPin, OUTPUT);
dataArrayRED[0] = 0x3F; //00111111 - 0 dataArrayRED[1] = 0x06; //00000110 - 1 dataArrayRED[2] = 0x5B; //01011011 - 2 dataArrayRED[3] = 0x4F; //01001111 - 3 dataArrayRED[4] = 0x66; //01100110 - 4 dataArrayRED[5] = 0x6D; //01101101 - 5 dataArrayRED[6] = 0x7D; //01111101 - 6 dataArrayRED[7] = 0x07; //00000111 - 7 dataArrayRED[8] = 0x7F; //01111111 - 8 dataArrayRED[9] = 0x6F; //01100111 - 9 // Key Selection dataArray2[0] = B01110111; // A Check display wiring, this has been modified! dataArray2[1] = B01111100; // b dataArray2[2] = B00111001; // C dataArray2[3] = B01011110; // d dataArray2[4] = B01111001; // E dataArray2[5] = B01110001; // F dataArray2[6] = B01101111; // g } void loop() { int val = 10; //this is for how many digits int i = map(analogRead (0), 0, 1023, 0, 20); // Scale Selection Display int h = map(analogRead (1), 0, 1023, 0, 7); // Key Selection Display { digitalWrite(latchPin, 0);
int digit2 = i % val; int digit1 = ( i - digit2 ) / val; int digit3 = h; shiftOut(dataPin, clockPin, dataArray2[digit3]); shiftOut(dataPin, clockPin, dataArrayRED[ digit2 ]); shiftOut(dataPin, clockPin, dataArrayRED[ digit1 ]);
digitalWrite(latchPin, 1);
} } void shiftOut( int myDataPin, int myClockPin, byte myDataOut) {
int i=0; int pinState; pinMode(myClockPin, OUTPUT); pinMode(myDataPin, OUTPUT); digitalWrite(myDataPin, 0); digitalWrite(myClockPin, 0); for (i=7; i>=0; i--) { digitalWrite(myClockPin, 0);
if ( myDataOut & (1<<i) ) { pinState= 1; } else { pinState= 0; } //Sets the pin to HIGH or LOW depending on pinState digitalWrite(myDataPin, pinState); //register shifts bits on upstroke of clock pin digitalWrite(myClockPin, 1); //zero the data pin after shift to prevent bleed through digitalWrite(myDataPin, 0); } digitalWrite(myClockPin, 0); }
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #18 on: April 30, 2011, 10:52:52 am » |
Constant array initialisers are probably easier. You can also write them in binary if you find conversion to and from hex difficult. Saves typing.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Online
Brattain Member
« Reply #19 on: April 30, 2011, 01:07:14 pm » |
It is much easier to initialises an array like this:- byte dataArrayRED[] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6F };
Logged
Ireland
Offline
Full Member
Arduino rocks
« Reply #20 on: April 30, 2011, 01:47:44 pm » |
 Thanks for your help AWOL & GRUMPY_MIKE.....Here's the now further simplified code for anyone who needs it and a link for "Binary to Decimal to Hexadecimal Converter" which I found useful! http://www.mathsisfun.com/binary-decimal-hexadecimal-converter.html
byte dataArrayRED[] = { 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6F }; // 0 1 2 3 4 5 6 7 8 9 byte dataArray2[] = { 0x77, 0x7c, 0x39, 0x5E, 0x79, 0x71, 0x6F }; // A b C d E F g
void setup() { pinMode(latchPin, OUTPUT); } void loop() { int val = 10; //this is for how many digits int i = map(analogRead (0), 0, 1023, 0, 20); // Scale Selection Display int h = map(analogRead (1), 0, 1023, 0, 7); // Key Selection Display { digitalWrite(latchPin, 0);
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #21 on: April 30, 2011, 02:07:59 pm » |
Any good reason all the "pinMode"s aren't in "setup"?
Logged
Ireland
Offline
Full Member
Arduino rocks
« Reply #22 on: April 30, 2011, 02:45:31 pm » |
If I place pinMode(myClockPin, OUTPUT); & pinMode(myDataPin, OUTPUT); in set up, then I must also "int myClockPin; & int myDataPin; at the beginning of my code. I must also leave them where originally positioned under "void shiftOut" in order for the code to run correctly. But maybe this is the way it should be done??? Can they be both under "set up" and "void shiftOut" ??
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #23 on: April 30, 2011, 03:27:19 pm » |
But you never change the pin assignments, so why bother making them parameters of shiftOut?
Logged
Ireland
Offline
Full Member
Arduino rocks
« Reply #24 on: May 01, 2011, 07:38:44 pm » |
 Ok, cool! Thanks AWOl. I see what you mean and corrected it. My confusion was having a mix of "dataPin" & myDataPin" etc, throughout the code. Here she is now.....
void setup() { pinMode(latchPin, OUTPUT); pinMode(clockPin, OUTPUT); pinMode(dataPin, OUTPUT); } void loop() { int val = 10; //this is for how many digits int i = map(analogRead (0), 0, 1023, 0, 20); // Scale Selection Display int h = map(analogRead (1), 0, 1023, 0, 7); // Key Selection Display { digitalWrite(latchPin, 0);
void shiftOut( int dataPin, int clockPin, byte dataOut) {
int i=0; int pinState; digitalWrite(dataPin, 0); digitalWrite(clockPin, 0); for (i=7; i>=0; i--) { digitalWrite(clockPin, 0);
if ( dataOut & (1<<i) ) { pinState= 1; } else { pinState= 0; } //Sets the pin to HIGH or LOW depending on pinState digitalWrite(dataPin, pinState); //register shifts bits on upstroke of clock pin digitalWrite(clockPin, 1); //zero the data pin after shift to prevent bleed through digitalWrite(dataPin, 0); } digitalWrite(clockPin, 0); }
Logged
