Topic: How to put [code] or [/code] literally in a forum post? (Read 262 times) previous topic - next topic
GypsumFantastic
Imagine (if you can) I wanted to explain code tags to someone on this forum.
I might want to say something like, "Type [ code ] then paste in your sketch, then type [ /code ] at the end"
Here I've used extra spaces to break up the tags and prevent the forum software from interpreting them. It works, kinda, but doesn't look quite right, and I think there's a risk that the inexperienced might parrot the extra spaces which would defeat the object.
So, how would I go about having the tags display in a forum post, but adding spaces? Is there a 'standard' way to go about it?
Delta_G
nobbc tags
[nobbc][code][/code][/nobbc]
Quote me to see all of it.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
larryd
Tell them to read #7 & 8
7. If you are posting code or error messages, use "code" tags
8. You can add attachments
http://forum.arduino.cc/index.php/topic,148850.0.html
No technical PMs.
The last thing you did is where you should start looking.
