Loading...
Pages: [1]   Go Down
Author Topic: How many millis() takes a delay()  (Read 801 times)
Rapa Nui
Offline Offline
God Member
Pukao hats cleaning services
View Profile
I'm troubleshooting an analog logger (based on the sdfat example) and duration of the delay(x) shows less millis difference than expected:
Exampe:
mil1 = millis();
delay(5000);
m = millis();
Serial.print(m-mil1);
gives me 4808. I am using 7.37MHz crystal.
P.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Your system probably needs an 8 Mhz crystal, as you crystal is lower you should get 5000 * (7.37 /8 ) = 4606 ... OK that is lower than what you got that's the theory (and in theory there is no difference between theory and practice but in practice ...)
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Rapa Nui
Offline Offline
God Member
View Profile
I was thinking the delay() is based on millis, thus I expected a delay(5000) would be equal or longer than 5000 millis for ANY crystal value. But I see the delay() is based on micros currently, where a lot of alchemy has been applied. It would be nice to have the delay() and millis() aligned in a way it will not be dependant on the crystal frequency... It cannot be a rocket science, though. smiley.P.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Quote
Due to a lack of a hardware floating-point unit and other constraints, early space flight computers used fixed point math.  So technically the millis implementation is "rocket science".
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
It is very close to equal if you set the appropriate number in whatever file deals with this, (boards.txt?)
Quote
These simple delay functions are based on the clock frequency, so they can't be independent of it. The only way to get an accurate and independant frequency would be to have another (normally external) clock source.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Rapa Nui
Offline Offline
God Member
View Profile
Frankly, I do not understand why the delay() and millis() shall be dependant on a crystal frequency entered in boards.txt.  My understanding is for the clock frequencies from 32KhZ to 20MHz one shall be able to compile a delay() and millis() where one millis() unit is very close to 1ms and a delay(3333) gives you a ~3333 millis units of difference. It must not be extremly precise (because of interrupts and other obstacles you may encounter) but basically delay() millis() and micros() shall be in a relationship such the values for millis() >=delay().
It means:
m1=micros();
delay_us(2000);
m2=micros();
m2-m1 is >= 2000
m1=millis();
delay(2000);
m2=millis();
m2-m1 is >= 2000
for ANY value of the crystal used (compiled).
P.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
The code for millis has to be told (at compile) the speed of processor clock.  There is no way for that to be determined later (at run).
Quote
The Arduino folks wanted an efficient millisecond clock and as many PWM pins as possible.  Those three goals drive the structure of the code and limit the clock speed choices.
The simple fact is that the code in wiring.c requires the processor clock to be a power of 2 (1 MHz, 2 MHz, ... 8 MHz, 16 MHz).  To support arbitrary clock speeds requires code that is more complicated (less efficient) and, in some cases, giving up PWM on timer 0.
Logged
Pages: [1]   Go Up
Print
Jump to:
