Topic: Error compiling for board NodeMCU 1.0 (ESP-12E Module). (Read 102 times) previous topic - next topic
Arduinogenie
Hallo,
kann mir jemand bei dieser Fehlermeldung helfen?
Hier nochmal das restliche Zeugs.
Arduino: 1.6.9 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
sketch\EMailSoftware.cpp: In function 'int sendEmail()':
EMailSoftware.cpp:528: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
       rv = Serial.println(F("EHLO 139.13.210.77"));
EMailSoftware.cpp:563: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:588: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:613: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:638: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:663: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:688: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:713: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:738: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
EMailSoftware.cpp:763: error: invalid conversion from 'size_t {aka unsigned int}' to 'EMAILSTATUS' [-fpermissive]
sketch\EMailSoftware.cpp: In function 'void PUSH_AND_SEND()':
EMailSoftware.cpp:821: error: 'sendingInProgress' was not declared in this scope
       sendingInProgress = true;
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
combie
Mache das doch mal bitte!
Das zählen der Ausgabezeichen schlägt fehl, weil die Typedefinitionen nicht stimmig sind.
Aber was da nicht stimmt?
KA, denn der Code ist geheim.
Schreie nach Besserem, bis du es auch erhältst.
Das noch Bessere verabschiedet sich rechtzeitig vor deinem Lärm.
Quelle: Martin Gerhard Reisenberg
amithlon
Hallo,
size_t ist unsigned int. Wie rc deklariert ist, verrät sein Code ja nicht.
Wenn der Sketch ursprünglich vom es vom AVR stammt, wäre unsigned int ein uint16_t, auf dem ESP aber ein uint32_t.
Warten wir also ab, ob wir noch erfahren, wer oder was EMAILSTATUS ist.
Gruß aus Berlin
Michael
michael_x
EMAILSTATUS ist offensichtlich EMAILSTATUS,  aber nichts was zum Datentyp size_t passt.
Ob nun die Variable rv den falschen Datentyp hat, oder ob sie besser nicht als Rückgabe-Wert für println verwendet würde, kann nur Arduinogenie wissen
