« on: April 23, 2011, 07:09:38 am » |
Hi All, I have a a QY-12864F GLCD panel. Using the example script that comes with the GLCD library works just fine. However any text it writes to the script i.e. GLCD.Puts("GLCD version ); Is just text and yes it works fine. When I try to replace this with a variable. I.E. String glcdVersion = "GLCD version "; GLCD.Puts(glcdVersion);
I get the following error when I try to compile error: no matching function for call to 'ks0108::Puts(String&)' Can anyone provide any advice on how to write a string variable to a GLCD using the GLCD library Thanks Simon
what?
« Reply #1 on: April 23, 2011, 11:43:52 am » |
Try using char instead it compiles without error but i dont have my glcd to hand to test it char glcdVersion[14] = "GLCD version "; GLCD.Puts(glcdVersion);
Dallas, TX USA
« Reply #2 on: April 23, 2011, 11:53:33 am » |
The String class was added after the glcd library Puts() function was written, so the glcd library gText class function Puts() does not support it. However, the Arduino Print class does support the String class and the glcd library supports the Print class. So you have two choices, you can either not use the String class for your strings or use the Print class function to print String class strings. The String class has extra overhead, so if you don't intend to manipulate the strings using the String class functions, I would not use the String class to save memory. So when not using the string class: char *glcdVersion = "GLCD version "; GLCD.Puts(glcdVersion);
Currently, if using the String class, you must use the Arduino Print class printing functions instead of directly using the glcd library gText functions like Puts(). String glcdVersion = "GLCD version "; GLCD.print(glcdVersion); I'll look into adding String class support to the glcd library gText class printing functions. --- bill
Dallas, TX USA
« Reply #3 on: April 23, 2011, 12:02:46 pm » |
Try using char instead it compiles without error but i dont have my glcd to hand to test it char glcdVersion[14] = "GLCD version "; GLCD.Puts(glcdVersion); When declaring character arrays for strings, unless you need the storage to be exactly a given size it is best to avoid specifying the array size. Simply let the compiler figure it out because if you make it too small you will get a compile error. Make it too large and unless you need the extra room, you waste memory. So use either of these two declarations instead. (both are equivalent) char glcdVersion[] = "GLCD version "; GLCD.Puts(glcdVersion); char *glcdVersion = "GLCD version "; GLCD.Puts(glcdVersion); --- bill
what?
« Reply #4 on: April 23, 2011, 01:15:20 pm » |
Thanks for that Bill, i'll keep it mind
Dallas, TX USA
« Reply #5 on: April 23, 2011, 03:33:58 pm » |
Simon, I have updated the glcd library to support the Arduino String class in Printf(), StringWidth(), and Puts() and have created a new RC release for the library.
So if you go grab the RC2 release, it should now work as you wanted it to.
But for simple strings like you have shown, it would use less code and more more importantly RAM if you declared it as a char * instead.
--- bill
« Last Edit: April 23, 2011, 03:44:15 pm by bperrybap »
« Reply #6 on: April 23, 2011, 04:59:58 pm » |
Hi Bill,
I very much appreciate your time. I feel a bit bad actually, because after your post I tried the print function and found it did not work, that lead me to realize that I was using the old library. Hope that I have not wasted too much of your time. As soon as I updated with the new GLCD library, I was able to print strings. I was only using char because it was the only option available in the library I had.
One other quick question. Is there any library out there which will allow me to supply a string of text and a maximum character width and have it return a string that is formated with line breaks so that line wraps do not occur in the middle of words?
Again, I (and I think everybody else) appreciates your time and effort on this library!
Simon
Dallas, TX USA
« Reply #7 on: April 23, 2011, 05:34:36 pm » |
Don't feel bad. You did discover that some of the glcd library printing functions didn't support the arduino String class.
As far as smart line/word breaks. Nothing that I've seen (but I've never really looked for it). The problem with modifying one string into another string is that it needs memory in order to do that. RAM is very precious on these small 8 bit micro-controllers. A better way to do it (as far as RAM usage goes) would be to write your own puts() function that handles it on the fly. In other words, it keeps track of the position it is in and then looks ahead after each word break (space character) and if the next word (all characters up to next space character) doesn't fit, then insert a new line and keeps going.
It would be a small routine that sits on top of PutChar().
That way it could even use strings that are only stored in Program memory vs in RAM like strings that declared with String or char *.
If you intend to use alot of strings, you may need to start storing the strings in flash vs RAM. Read up on PSTR() and have a look at the new BigNums example in the RC2 release of the glcd library.
--- bill
« Reply #8 on: April 24, 2011, 06:58:43 am » |
Hi Bill, Just about there with my new project. One thing that I am still struggling with however is getting new lines to be displayed on the GLCD The following code works just work GLCD.SetTextMode(SCROLL_UP); GLCD.CursorToXY(1,1); GLCD.ClearScreen(); GLCD.println("flkdsjk\nfjdslfjkdfj\ndlfkj\nlsdjf");
A line wrap replaces the \n escape code, however the following code just displays the \n as text while (Serial.available()){ p = Serial.read(); lcdText += p; } GLCD.SetTextMode(SCROLL_UP); GLCD.CursorToXY(1,1); GLCD.ClearScreen(); GLCD.println(lcdText);
Any idea how I can get the escape codes to be recognized when read from serial? Thanks Simon
« Reply #9 on: April 24, 2011, 08:32:32 am » |
Actually don't worry about my last post. Not sure why, but the /n escape code works fine when I send it from python via Serial. For some reason it just does not work when I send it from the Arduino Serial monitor
Thanks Anyway
Simon
« Reply #10 on: April 25, 2011, 03:04:26 pm » |
Hope I am not starting to annoy anyone with all my questions. But....... When I use the GLCD.SetTextMode(SCROLL_UP); (or SCROLL_DOWN) the LCD clears the screen as part of the scroll and starts again from the top. In order for users to read a long string of text, I am writing to the LCD in a teletype fashion that is slow enough to read, as long as the last text written scrolls up the screen, however as I just said it simply clears the screen. Here is my code GLCD.CursorToXY(1,1); GLCD.ClearScreen(); GLCD.SetTextMode(SCROLL_UP); for (int x = 0; x < lcdText.length(); x++) { delay(50); GLCD.print(lcdText.substring(x,x+1)); }
Is there a way to carry out a true scrolling of text. Thanks Simon
« Last Edit: April 25, 2011, 03:26:09 pm by SimonUK »
Dallas, TX USA
« Reply #11 on: April 25, 2011, 05:27:05 pm » |
I can't tell completely what you have done or were trying to do with that small code fragment. There are other things like what font you have selected, if you have modified the default text area, and how you have initialized your String class object that will affect things.
For example, if you don't select a font for the GLCD object, no text will be displayed when using the GLCD object printing functions.
I have run a simple test using your code fragement, using the system5x7 font, using the default text area in the GLCD object and it works as expected. The text wraps when necessary, and eventually will scroll the text area (up or down, depending on how it is initialized). You will see this slow text area wrapping/scrolling in the GLCDdemo sketch for two different fonts.
If you explained more of what you are trying to do and showed more of the sketch it would be helpful.
The text wrapping/scrolling code does not ever clear the text area or the glcd display screen. (while a text area may exist over the entire display, a text area is different from the entire display screen) The SetTextMode() call does not scroll or clear the text area in any way. It merely sets the text mode. The text mode SCROLL_UP and SCROLL_DOWN sets the direction the text area will be wrapped & scrolled when necessary after a line wrap.(UP scrolling with down wrapping being the default) The only part of the text area that is "cleared" is a small section that is large enough to hold a new row of text after the other text in the text area has been scrolled. This is at the bottom when scrolling up, and at the top when scrolling down.
Normally, when dealing with text areas and wrapping and scrolling you won't want to use CursorToXY(x,y), as that is setting the absolute X & Y pixel offsets within the text area for the character rendering. CursorTo(column, row) sets the character rendering position within the text area based on character positions of the currently selected font. (works best with fixed width fonts).
The reason I bring this up is using a x,y position of 1,1 inside a text area is not a corner of a text area. It is one pixel in. All areas are 0 based. (See the html documentation for details on the text area function calls - it is the gText class)
When scrolling up, the upper left corner would be 0,0 If using an x/y initial position of 1,1 when the scroll finally does happen, the initial scroll may look a bit strange if using something like the system5x7 font because initially there will not be enough room for that 8th row of text to wrap so there will be bit of an extra pixel gap between row7 and row8 of text as the scrolling code makes room for the new row to sit along the bottom edge of the text area.
When dealing with text inside text areas, it is better to use character row/column addressing with CursorTo() and things like ClearArea() when possible rather than absolute x&y positions with CursorToXY() and ClearScreen().
--- bill
« Reply #12 on: April 26, 2011, 07:53:39 am » |
Hi Bill, Here is the code I currently have loaded on my Arduino If the first letter of the code received is a 't' then text is expected next and sent to the LCD. The problem as I mentioned is that any text larger than the display limit for the LCD is not scrolled, the LCD simply clears the screen and starts again from the top. Can you see what the problem is which my code? Thank you Simon
//start GLCD #include <glcd.h> #include "fonts/allFonts.h" // system and arial14 fonts are used #include "bitmaps/allBitmaps.h" // all images in the bitmap dir
String lcdText; unsigned long startMillis; unsigned int loops = 0; unsigned int iter = 0; //end GLCD
int unreadFlag; //1 = True, 0 = False int emailButtonState = 0; char p; void setup() { GLCD.Init(); // initialise the library, non inverted writes pixels onto a clear screen // initialize the digital pin as an output. // Pin 13 has an LED connected on most Arduino boards: pinMode(8, OUTPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); pinMode(11,OUTPUT); pinMode(13,OUTPUT); pinMode(12,INPUT); Serial.begin(9600); //Start GLCD delay(500); // allow time for LCD to reset GLCD.ClearScreen(); GLCD.SelectFont(System5x7); // switch to fixed width system font GLCD.print("Welcome to i-Monitor\n\nSimon Carr"); //End GLCD }
void loop() { if (Serial.available()>0) { p = Serial.read(); //p = Serial.read(); }
switch (p){ case 'x': unreadOn(); break; case 'o': unreadOff(); break; case 'p': flashLED(10,1); break; case 'a': emailAlertOn(); break; case 't': delay(100); lcdText = ""; while (Serial.available()){ p = Serial.read(); lcdText += p; } GLCD.ClearScreen(); GLCD.CursorToXY(0,0); GLCD.SelectFont(System5x7); // switch to fixed width system font GLCD.SetTextMode(SCROLL_UP);
} break;
} p=' '; emailButtonState = digitalRead(12); if (emailButtonState == HIGH && unreadFlag == 1){ beep(1); unreadOff(); emailAlertOf(); } if (emailButtonState == HIGH){ serialWrite('e'); //Instructs python script to open email program delay(2000); }
void unreadOn(){ if (unreadFlag == 0){ digitalWrite(8,HIGH); flashBeep(2); unreadFlag = 1; } else{ flashBeep(1); } }
void unreadOff(){ digitalWrite(8,LOW); unreadFlag = 0; }
int flashLED(int pin, int times){ for (int a=0;a<times;a++){ digitalWrite(pin,HIGH); delay(250); digitalWrite(pin,LOW); delay(250); } }
int beep(int times){ for (int a=0;a<times;a++){ digitalWrite(11, HIGH); delay(250); digitalWrite(11,LOW); delay(250); } }
int flashBeep(int times){ for (int a=0;a<times;a++){ digitalWrite(9, HIGH); digitalWrite(11,HIGH); delay(250); digitalWrite(9,LOW); digitalWrite(11,LOW); delay(250); } }
char serialWrite(char data){ Serial.write(data); }
void emailAlertOn() { digitalWrite(13,HIGH); flashBeep(3); }
void emailAlertOf() { digitalWrite(13,LOW); }
Dallas, TX USA
« Reply #13 on: April 26, 2011, 12:08:48 pm » |
I still not understanding what you you seeing/experiencing or expecting. I don't understand what you mean by: "Any text larger than the display limit for the LCD is not scrolled, the LCD simply clears the screen and starts again from the top".
Text areas simply display characters at the next available location inside the text area and if there is not room on a line, the line is wrapped within the text area. If there is not room to wrap, the entire text area is scrolled to make room for the new line. The direction of wrap and scroll is determined by the scroll mode. One thing to keep in mind is that since there is no other buffering or memory for text or graphics anywhere else other than the glcd display memory itself, once text is scrolled off the text area that text is gone & lost forever.
Likewise, because there is no other memory other than the glcd display memory itself, All the text areas and the graphic area of the display share the same memory. So if you do a ClearScreen() the entire glcd display is cleared and so all the text inside all text areas will also be cleared. If you create a text area that is smaller than the full display you can clear that text area using ClearArea() and only that portion of the display will be cleared and the other portions of the display will be untouched.
I took your exact sketch and ran it on my Teensy++ board. (I had to remove your digitalWrite() and pinMode() calls as they conflicted with the Teensy glcd pins)
When I sent a very long string from the serial monitor starting with a 't', it worked as expected. The text printed slowly, wrapped and when it reached the right edge of the text area it started to scroll the text up as needed.
The serial buffering in the serial code varies depending on which AVR processor you have. Some get 128 bytes and some get only 32 bytes. I don't know how much text data you are sending and what the inter character timing is. Keep in mind that if you send more than 100 characters, you may have issues as you only wait 100 ms after receiving the 't'. And if you send more than 128 characters the additional characters will be lost as the buffer will overflow while you are waiting.
A few other comments: ClearScreen() really isn't for text areas. It clears the entire display. ClearArea() is for text areas. (When using the default text area in GLCD, since it is the full display, it is a bit difficult to them apart) ClearArea() will home the cursor when the area is cleared. ClearScreen() will not alter the text location because it is not tied to a text area. There is no need to select the font and set the sroll direction over and over again. Once you set those, they will be remembered until you change them.
See the included html documentation for the full list of functions available for text areas and information on how they work. Text areas use the gText class funtions.
--- bill
« Reply #14 on: April 27, 2011, 03:25:30 am » |
The only way I can describe the symptom is that text starts from the top left of the display and fills all the way down to the bottom. If there is more text to come, I would expect the top line to be removed and all other lines move up one line to fill it's place and new text appear on the now empty bottom line.
Instead, when the text fills the screen down to the bottom right hand corner, the display clears it's self and the remaining text starts to be printed from the top left of the screen again.
I have tried to make a bit of graphic example below (LCD is bigger than this of course).
Imagine I am sending this text to the LCD "This is some text that I have written to show what I have tried to put in words above. A picture is better than words."
Here is what I would expect screen 1 |-----------------------------------| |This is some text that I have | |written to show what i have | |tried to put in words above | |-----------------------------------| screen 2 |-----------------------------------| |written to show what i have | |tried to put in words above | |A picture is better than words | |-----------------------------------|
Here is what I actually get
screen 1 |-----------------------------------| |This is some text that I have | |written to show what i have | |tried to put in words above | |-----------------------------------| screen 2 |-----------------------------------| |A picture is better than words | | | | | |-----------------------------------|
Hope this makes it clearer what the problem is. As you can imagine, it makes it much harder to read the message when all the relevant text on previous lines (especially if it is mid sentence) has been removed.
Thanks Simon
