Topic: Manual Counter Item With Push Button (Read 51 times) previous topic - next topic
Novi_AY
I'am making a project arduino with theme Manual counter item wish push button, after i try to make it, i can make manual counter with push button, but i have a problem about that. The problem is i can't running program with 2 command on the 1 push button. How this solution ?
Thank you.
Delta_G
#1
Jan 24, 2019, 02:44 am Last Edit: Jan 24, 2019, 02:45 am by Delta_G
Thank you.
Write your code properly.  Fix the errors and problems in your code.  Then it will functioning correctly.
If your code doesn't work the way you want it to then you need to fix the code.  Only someone who can see your code would be able to help you with that.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
