Topic: Servos and steppers on an Arduino Mega (Read 854 times) previous topic - next topic
Luis_de_Morais
what sort of limitations should I expect by trying to control servo motors and stepper motors with the same Arduino Mega board?
From the Servo library intructions: "The Servo library supports up to 12 motors on most Arduino boards and 48 on the Arduino Mega." Is the number 48 impacted if I also use the Stepper library?
Thanks,
Luís
robtillaart
Hi Luis,
you posted the question twice in this subsection , once with a half title, could you please remove it?
The most important thing is that the servos should have a separate power supply, especially if you want to connect 48. Connect the GND from the Arduin to the GND of the other power supplies and it should work. Furthermore keep in mind that servo's need serious time to get their position but you should build your application logic so that you don't wait for servo 1 reached its destintion angle before applying commands to the next.
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Luis_de_Morais
Thanks Rob. The other "half post" has been removed!
My question is more about the hardware resources that libraries servo and stepper use. Like timers. From my experience I know that if you use library servo (which uses timer1) you lose the possibility of having PWM on certain pins. Therefore if I want to keep all "PWM" capabilities I can not control all servos with a Mega that I otherwise would be able to.
"On the Mega, up to 12 servos can be used without interfering with PWM functionality; use of 12 to 23 motors will disable PWM on pins 11 and 12. "
Are there any similar issues if I want to control a stepper (instead of a DC motor)? Trying to be more objective, how many servos will I still be able to control with a Mega if I'm already controlling a stepper? Is the number 48 still valid?
Thanks
Luis
