Topic: A better way to format SD cards (Read 17365 times) previous topic - next topic
fat16lib
For three years I have been trying to find an easy way to correctly format SD cards for optimal use on the Arduino.
I finally decided to write a sketch to format SD cards. It is included as one of the examples, SdFormatter.pde, in the 20110414 beta of SdFat:
http://code.google.com/p/beta-lib/downloads/list
I decided to write SdFormatter.pde since the only program I know that complies with the SD File System Specification is here:
http://www.sdcard.org/consumers/formatter_3/
It only runs on PCs and formats small SD cards as FAT12.  PC/Mac/Linux format utilities do not comply with the above standard and do not produce optimal file system structures for the Arduino.
For SD/SDHC cards larger than 64 MB this sketch attempts to match the format generated by the sdcard.org formatter.  For smaller cards, 16 - 64 MB, it use FAT16 instead of FAT12.
It chooses the best file system, FAT16/FAT32, the optimum cluster size, and aligns file system structures on the card's flash erase boundaries.
This version has the chip select pin hard coded as the SPI SS pin.  This will be a menu option in the future.
To change chip select to pin 4 replace line 439
Code: [Select]
  if (!card.init()) sdError("card.init failed");
with
Code: [Select]
  if (!card.init(SPI_HALF_SPEED, 4)) sdError("card.init failed");
Please let me know how it works.
kalum
This sketch can erase and/or format SD/SDHC cards.
Erase uses the card's fast flash erase command.
Flash erase sets all data to 0X00 for most cards
and 0XFF for a few vendor's cards.
Cards larger than 2 GB will be formatted FAT32 and
smaller cards will be formatted FAT16.
Warning, all data on the card will erased.
Enter 'Y' to continue: Y
Options are:
E - erase the card and skip formatting.
F - erase and then format the card. (recommended)
Q - quick format the card without erase.
Enter option: F
Card Size: 3782 MB, (MB = 1,048,576 bytes)
Erasing
All data set to 0x00
Erase done
Formatting
Blocks/Cluster: 64
FAT32
Format done
I ran the following tests on the formatted card moved to the computer.....to analyse the file system, hope it helps.....
kalum@d:~$ sudo fdisk  /dev/mmcblk0
WARNING: DOS-compatible mode is deprecated. It's strongly recommended to
         switch off the mode (command 'c') and change display units to
         sectors (command 'u').
Command (m for help): p
Disk /dev/mmcblk0: 3965 MB, 3965190144 bytes
49 heads, 48 sectors/track, 3292 cylinders
Units = cylinders of 2352 * 512 = 1204224 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1               4        3293     3868160    b  W95 FAT32
kalum@d:~$ sudo fsck.vfat /dev/mmcblk0p1
dosfsck 3.0.7, 24 Dec 2009, FAT32, LFN
/dev/mmcblk0p1: 0 files, 1/120752 clusters
fat16lib
I have had some mail about why there are no options for SdFormatter.  The reason is that SD Association's standard specifies FAT16 for card's 64 MB - 2 GB and FAT32 for larger cards.  The cluster size is also specified.
I wrote SdFormatter since people often don't understand the internal structure of SD cards and the reasons for the SD File System Specification issued by the SD Association.
Here is an extreme example. Note the write speed difference with the correct format and layout. 14.13 KB/sec vs. 291.04 KB/sec. The Windows 7 layout kills the flash controller in this card. With the correct layout it is one of the fastest cards around.
I formatted a 512 MB card FAT32 with small, 1 KB, clusters using Windows 7. Here are the results of running the bench.pde example.
Quote
Type any character to start
Free RAM: 1075
Type is FAT32
File size 1MB
Starting write test. Please wait up to a minute
Write 14.13 KB/sec
Starting read test. Please wait up to a minute
Read 244.56 KB/sec
Done
I reformatted the card with SdFormatter.pde. Here is the results with FAT16 and the layout and cluster size specified by the standard:
Quote
Free RAM: 1075
Type is FAT16
File size 1MB
Write 291.04 KB/sec
Read 326.80 KB/sec
Done
kalum
Quote
Free RAM: 1075
Type is FAT16
File size 1MB
Write 291.04 KB/sec
Read 326.80 KB/sec
Done
Impressive indeed. I did not notice any speed improvement as i use linux's mkfs.vat which seems to get things correctly. However your latest (sdfat beta) library is much faster than V1, it's read benchmark gives me 270K/sec whereas the old one gave me only 250K/sec.
fat16lib
I did some tests on Ubuntu 10.04.  With a totally erased SD.  The disk utility formats small cards as a super floppy, no MBR.   This is not allowed in the standard but I accept it in SdFat.
With larger cards it tends to pick a cluster size that is small for optimum performance.
Tried mkfs.vfat and it never chooses a format that complies with the SD File System Specification.  It often fails to align file structures on flash erase group boundaries.  It tends to pick a cluster size that is too small.
Most card perform fairly well with the format mkfs.vfat chooses but some are degraded a bit.
Frédéric_Plante
Don't want to be a pain, but where is your sd formating programe these days?
As we fight our way northward into the great unknown, only that one thing remains certain...
pYro_65
I think there is a formatting example in the sdfat library you can use with a duino to format if needed.
https://code.google.com/p/sdfatlib/
Forum Mod anyone?
https://arduino.land/Moduino/
KGDTDM
On the subject of the ARDUINO sketch that will allow it to format SD cards. Apparently google has dropped the link and doesn't serve the data anymore. Neither does the server on the link you are given as a suggestion. I can use a nice sketch to perform the SD card formatting. Anyone?
fat16lib
SdFat moved to GitHub.  The latest formatter is here.
I am about to upgrade SdFat using SdFat-beta.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
