Topic: problem with "avr-size" (Read 2178 times) previous topic - next topic
Federico Vanzati
Hello,
I'm trying to use the avr-size utility unsuccessfully. I'm running Windows7
what i do is:
- open command prompt
- compile (verify) my sketch
- with command "cd" i move into my compiled sketch folder ( ex: C:\Users\Federico\AppData\Local\Temp\build2161693329745786396.tmp )
- write the command: avr-size MySketchName.cpp.elf and press enter...
What happen is:
"avr-size" is not recognized as internal or external command, an executable program or batch file
avr-size should be included in the avr-gcc toolchain that i suppose comes with Arduino IDE! Am I right?
Do you have any advice to get working this utility on my computer?
F
davekw7x
#1
Apr 23, 2011, 07:56 pm Last Edit: Apr 23, 2011, 07:59 pm by davekw7x Reason: 1
Hello
Hi.
Quote from: Federico Vanzati
I'm trying to use the avr-size utility...
The operating system does not know where to find executables unless either
1.  The file is in a directory defined by the %path% environment variable
or
2.  You give it the complete path name as part of the command.
And, yes, you are correct: avr-size.exe  (and other avr-stuff) is under the arduino installation directory:
\\whatever\arduino-0022\hardware\tools\avr\bin
Append that directory to your %path%.  (In Windows XP, you can set and modify environment variables from the Control Panel->System->Advanced->Environment Variables box.  I don't know exact details for later versions of Windows.)
Regards,
Dave
westfw
Quote
yes, but the ide invokes the programs explicitly, and does NOT modify your default system paths to include all of the binary directories that it provides.
Federico Vanzati
so how can i modify something for get running avr-size.exe?
F
westfw
Like Dave said:  \\whatever\arduino-0022\hardware\tools\avr\bin
For example, I have a \bin\ directory where I put less formal installs, and I can do:
C:\Documents and Settings\Bill Westfield>c:\bin\arduino21\hardware\tools\avr\bin\avr-size.exe --help
Usage: c:\bin\arduino21\hardware\tools\avr\bin\avr-size.exe [option(s)] [file(s)]
Displays the sizes of sections inside binary files
If no input file(s) are specified, a.out is assumed
The options are:
  -A|-B|-C  --format={sysv|berkeley|avr}  Select output style (default is berkeley)
            --mcu=<avrmcu>            MCU name for AVR format only
  -o|-d|-x  --radix={8|10|16}         Display numbers in octal, decimal or hex
  -t        --totals                  Display the total sizes (Berkeley only)
            --common                  Display total size for *COM* syms
            --target=<bfdname>        Set the binary file format
            @<file>                   Read options from <file>
  -h        --help                    Display this information
  -v        --version                 Display the program's version
Within a particular session, the cmd window history functions are very useful.  If you're going to be doing this a lot, you can add the appropriate directory to your path:???
path c:\bin\arduino21\hardware\tools\avr\bin;%path%
(either manually, in some "avdev-setup.bat" file, or even autoexec.bat)
Federico Vanzati
Wow thanks westfw and all others posted here!
For now, I used the temporary command:
Code: [Select]
path C:\Users\Federico\Desktop\arduino-0021\hardware\tools\avr\bin;%path%
to add the executable to the windows path, then move into the compiled sketch folder and launch the command:
Code: [Select]
...>cd C:\Users\Federico\AppData\Local\Temp\build4288029111388491449.tmp
C:\Users\Federico\AppData\Local\Temp\build4288029111388491449.tmp>avr-size SketchName.cpp.elf
And it works well!!
Now i need try to find the "autoexec.bat" and add the path there...
F
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
