Topic: Algo thermistance 4.7k (Read 2580 times) previous topic - next topic
klgui4
Salut à tous,
Après quelques recherches j'ai réussi à trouver un code fonctionnel pour me donner une température grâce à une thermistance 4.7k grâce à une réponse dans la partie Italien de ce forum, voici le code :
Code: [Select]
#include <math.h>
//Schematic:                                      modified 4.K by forex2
// [Ground] ---- [10k-Resister] -------|------- [Thermistor] ---- [+5v]
//                                Analog Pin 0
double Thermistor(int RawADC) {
// Inputs ADC Value from Thermistor and outputs Temperature in Celsius
//  requires: include <math.h>
// Utilizes the Steinhart-Hart Thermistor Equation:
//    Temperature in Kelvin = 1 / {A + B[ln(R)] + C[ln(R)]^3}
long Resistance;  double Temp;  // Dual-Purpose variable to save space.
Resistance=((10240000/RawADC) - 10000);  //   Calculation is actually: Resistance = (1024 * BalanceResistor/ADC) - BalanceResistor
Temp = log(Resistance); // Saving the Log(resistance) so not to calculate it 4 times later. // "Temp" means "Temporary" on this line.
Temp = 1 / (0.0012954816 + (0.00023539242 * Temp) + (0.00000011285038 * Temp * Temp * Temp));   // Now it means both "Temporary" and "Temperature"
Temp = Temp - 273.15;  // Convert Kelvin to Celsius                                         // Now it only means "Temperature"
// BEGIN- Remove these lines for the function not to display anything
  Serial.print("ADC: "); Serial.print(RawADC); Serial.print("/1024");  // Print out RAW ADC Number
  Serial.print(", Volts: "); printDouble(((RawADC*5)/1024.0),3);   // 5 volts is what my USB Port outputs.
  Serial.print(", Resistance: "); Serial.print(Resistance); Serial.print("ohms");
// END- Remove these lines for the function not to display anything
// Uncomment this line for the function to return Fahrenheit instead.
//Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert to Fahrenheit
return Temp;  // Return the Temperature
void printDouble(double val, byte precision) {
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimal places
  // example: printDouble(3.1415, 2); // prints 3.14 (two decimal places)
  Serial.print (int(val));  //prints the int part
  if( precision > 0) {
    Serial.print("."); // print the decimal point
    unsigned long frac, mult = 1;
    byte padding = precision -1;
    while(precision--) mult *=10;
    if(val >= 0) frac = (val - int(val)) * mult; else frac = (int(val) - val) * mult;
    unsigned long frac1 = frac;
    while(frac1 /= 10) padding--;
    while(padding--) Serial.print("0");
    Serial.print(frac,DEC) ;
#define ThermistorPIN 0   // Analog Pin 0
double temp;
temp=Thermistor(analogRead(ThermistorPIN));           // read ADC and convert it to Celsius
Serial.print(", Celsius: "); printDouble(temp,3);     // display Celsius
Serial.println("");                                   // End of Line
delay(100);                                           // Delay a bit... for fun, and to not Serial.print faster than the serial connection can output
Le code fonctionne très bien, cependant je ne comprends pas bien l'algorithme, n'y a t'il pas moyen de rendre ça plus simple ?
Merci
fdufnews
Quote
Tout est là:
http://fr.wikipedia.org/wiki/Thermistance
