Topic: Switching between two projects without headache (Read 1 time) previous topic - next topic
liudr
I've made a phi-connect system to manage arduino wires. It easily helps you switch between several projects without having to disconnect and reconnect tons of wires, saving you so much time.
Here is a picture:
Here is a video:
I have two projects on one board and I switched between the two project in seconds.
http://www.youtube.com/watch?v=-8-r-VNpRvw
I wish I had this a while ago so I didn't have to  =( when I took my arduino out of this project. With phi-connect, I can take out the arduino and put it back in within a few second, no memorization of which wire goes where.
You can also use this system to tidy your breadboard and arduino, ridding the crazy jumper wires. Plus if you use it in finished projects, you can remove your arduino and return it any time you want, all with ease.
Please visit my blog for more information and where to get it:
http://liudr.wordpress.com/gadget/phi-connect/
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Nikka93
Si
That's a really good idea!
A lot cheaper than having loads of Arduino boards, and then forgetting which serial port you are connected to.
I write books about Arduino and Electronics: http://simonmonk.org
bld
I normally solve this problem by buying another arduino :D
Have you thought about making some with buttons and pull-up resistors on? Or maybe with voltage divider for the buttons?
Just to have some options to make it easier for some projects.
captain-slow.dk | non contagious!
liudr
Thanks si. Someone beat me to it but mine connects buses with 5v/gnd and only uses one cable compared with three :)
liudr
bld,
I could. Will you describe what you would do with these buttons? It makes me understand more about where to put them and how many to add.
FYI, if you connect buttons to arduino pins, you can enable internal pull-up resistors so you don't need external resistors.
bld
bld,
I don't need any, was just brainstorming for future ideas.
And yes, there are internal pull-up, but I still prefer external :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
