Loading...
Pages: [1] 2   Go Down
Author Topic: IDE 0022 Serial monitor bug?  (Read 602 times)
USA, OH
Offline Offline
Jr. Member
View Profile
14400 and 28800 shows garbage. All other settings are OK.
This is IDE issue, when monitoring serial port with other software, data looks normal.
Example sketch:
  Serial.begin(14400);
      Serial.println("Test");
      delay(20);
Example of garbage output:
f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n f×n
OS Windows XP SP3, processor Intel P4 2.8GHz, RAM 2 Gb; board Ard.Duemilanove, chip 328 (the same with 168)
FTDI Driver 5/19/2006 ver.2.0.0.0
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
I have had a few issues with the serial monitor acting up - I wonder if it's anything to do with the modified txrx dll that I (and many others) installed to sort out the slow loading.
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Switched to latest available FTDI driver 3/18/2011 2.8.14.0 with no result smiley-sad
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Is this with an un-modified version of the IDE?
Have you tried a different version to see if you still see the issue?
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
I am not aware of what 'modified IDE' is; I just downloaded arduino-0022.zip, unzipped it and ran arduino.exe
The same result I had with IDE 0017.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Well the answer will be no then smiley-razz
Hmm, I haven't heard of this problem on 0017.
If you have the board set to 14400, does it work on any other settings (wrong baud rates) in the IDE serial monitor?
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
No, no other speed settings  convert garbage into text.
But I have noticed that when I use Serial.begin(9600) (serial output is OK at IDE setting 9600), I still can see this output when I switch serial monitor to 14400. This happens _only_ on 9600. Any other board rates only produce correct output when serial monitor is set to matching speed.
Just tried the same on a different computer, Windows 7, IDE 0022. Same bug.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Have you checked your serial port settings in device manager?
8 Data bits, No parity, 1 Stop bit and No flow control
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Yessir!
As I said, I can see correct output on 14400 when using 'third party' serial port monitor.
This is obviously the bug of Arduino IDE.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Yeah - just trying to check all angles as I haven't seen this one before.
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Can you try it yourself in similar environment?
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Edit: Yeah I'll try it
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Just open new sketch, copy  the code from first message, upload and enjoy smiley
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Works fine here for 14400 and 28800 - on the Arduino IDE and X-CTU serial monitor and PUTTY serial monitor.
I suspect that it's a USB cable issue or a board connection issue and the arduino IDE serial monitor is simply less resilient to noise or something than better alternative serial monitors.
Not sure why it would only occur at those baud rates but I'm pretty sure now it's not an IDE issue specifically.
Logged
USA, OH
Offline Offline
Jr. Member
View Profile
Definitely not a cable, just tried another one, brand new with same result. Well, then it is only one reason: my board smiley-sad
Probably some glitch in communication chip. Unfortunately, I don't have another board to compare. But it also proves Arduino serial monitor is not 'resilient' enough compared to every other serial monitors:(
Thanks for your time, man!
Logged
Pages: [1] 2   Go Up
Print
Jump to:
