I'm very new to the Arduino and to C/C++, so please be patient
I'm trying to do a bootlogo on a graphic LCD but since it uses a lot of RAM, I thought of putting the logo in ROM and change the LCD library to read it from there.
The code below works perfectly without the progmem and pgm_read_byte_near. If I add the as below, the lcd image is corrupted but I can see the logo string correctly on the serial monitor and the debug print shows no memory being used (well, 1 byte
I'm having trouble getting the LCD library to use the ROM data. Can't get it to work with the Flash library or with PROGMEM directly.
A bit of help?
// Define DEBUG to produce verbose output to console
// Note: _DO NOT_ define DEBUG if using D0 (RX) and D1 (TX) for serial comms
#define DEBUG
#define BAUD_RATE 115200 // Baud rate, for serial communication with PC
// Define GRAPHIC_LCD to use a 128x64 LCD from DFRobot.com
// Note: define GRAPHIC_LCD_BOOTLOGO to show a boot logo. USES HUGE AMOUNTS OF RAM!
#define GRAPHIC_LCD
#define GRAPHIC_LCD_BOOTLOGO
// Allows us to debug the sketch during development and in case of issues
#ifdef DEBUG
#include "DebugUtils.h"
#endif
#include <Flash.h>
#ifdef GRAPHIC_LCD
#include <LCD12864RSPI.h>
#endif
#ifdef GRAPHIC_LCD_BOOTLOGO
; LCD bitmap - size 128x64 pixels, black/white image
prog_uchar logo[] PROGMEM =
'S', 'T', 'A', 'R', 'T', 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* */
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, /* */
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 'E', 'N', 'D', /* */
#endif
void setup() // run once, when the sketch starts
#ifdef DEBUG
Serial.begin(BAUD_RATE);
#endif
DEBUG_PRINTLN("Booting sketch.");
#ifdef GRAPHIC_LCD
DEBUG_PRINTLN("Initializing 128x64 Graphic LCD.");
LCDA.Initialise(); // INIT SCREEN
delay(100);
DEBUG_PRINTLN("Displaying 128x64 1bit monochrome boot logo.");
LCDA.DrawFullScreen(logo);//LOGO
delay(3000);
#endif
DEBUG_PRINTLN("Clear LCD.");
LCDA.CLEAR();
delay(10);
for(int i=0; i<1024; ++i)
Serial.print(pgm_read_byte_near(&logo[i]));
#endif
void loop() // run over and over again
Below is the function that shows the bitmap on the lcd. Part of the LCD12864RSPI library from DFRobot.com
void LCD12864RSPI::DrawFullScreen(uchar *p)
int ygroup,x,y,i;
int temp;
int tmp;
for(ygroup=0;ygroup<64;ygroup++) //дÈëÒº¾§ÉϰëͼÏ󲿷Ö
{ //дÈë×ø±ê
if(ygroup<32)
x=0x80; // Set Graphic Display RAM Address - vertical address first
y=ygroup+0x80;
x=0x88;
y=ygroup-32+0x80;
WriteCommand(0x34); //дÈëÀ©³äÖ¸ÁîÃüÁî - Function Set - 8 bit Interface - Extended Instruction
WriteCommand(y); //дÈëyÖá×ø±ê
WriteCommand(x); //дÈëxÖá×ø±ê
WriteCommand(0x30); //дÈë»ù±¾Ö¸ÁîÃüÁî - Function Set - 8 bit Interface - Basic Instruction
tmp=ygroup*16;
for(i=0;i<16;i++)
temp=p[tmp++];
WriteData(temp);
WriteCommand(0x36); //ÏÔʾͼÏó - Function Set - 8 bit Interface - Extended Instruction - Graphic Display ON
Since the Flash Library has a "#define FLASH_LIBRARY_VERSION 3", I was thinking of changing the LCD library function to something like:
#ifdef FLASH_LIBRARY_VERSION
//new code for Flash
// old code, no flash access
#endif
PS: had to cut the logo var when pasting here since the forum will not allow more than 9500 characters.
