Loading...
Pages: [1]   Go Down
Author Topic: How to save structure in EEPROM  (Read 408 times)
Offline Offline
Newbie
View Profile
Hi all
I need to save some settings of my application.
I found this example http://arduino.cc/playground/Code/EEPROMWriteAnything, but I can't compile this code.
Code:
#include <EEPROM.h>
template <class T> int EEPROM_writeAnything(int ee, const T& value)
    const byte* p = (const byte*)(const void*)&value;
    int i;
    for (i = 0; i < sizeof(value); i++)
 EEPROM.write(ee++, *p++);
    return i;
template <class T> int EEPROM_readAnything(int ee, T& value)
    byte* p = (byte*)(void*)&value;
    int i;
 *p++ = EEPROM.read(ee++);
    return i;
double testInt[12] = { -12.5, -10.00, -5.7, 0, 2.45, 2.90, 3.10, 4 , 5.6, 7.9, 5.5, 4};
byte noElem = 12;
unsigned int baseAddr = 0;
unsigned int n = 0;
  // write data to eeprom
  for (int i=0; i <= noElem-1; i++){
    n = EEPROM_writeAnything( (i*4)+baseAddr, testInt[i]);
  // read data back
    double val;
    int addr = (i*4)+baseAddr;
    n = EEPROM_readAnything( addr, val);
    Serial.println(val);
 Error is:
Quote
sketch_apr24a:-1: error: expected ',' or '...' before '&' token
sketch_apr24a:-1: error: ISO C++ forbids declaration of 'T' with no type
sketch_apr24a:0: error: 'T' has not been declared
Can you give some advices to make this code work?
Happy debugging,
Johhik
Logged
Left Coast, USA
Offline Offline
Sr. Member
Sometimes I just can't help myself.
View Profile
...Can you give some advices to make this code work?
Some explanation here:
http://arduino.cc/forum/index.php/topic,56627.msg406522.html#msg406508
Regards,
Dave
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
There is some kind of bug with arduino IDE version 22 that prevents the templete from being compiled correctly. A work around is to put the templete in a tabbed window in the IDE and include it in your main sketch.
templete code in tabbed window named eetest.h :
Code:
#include <WProgram.h>
    int i;
    return i;
    int i;
    return i;
Main sketch code example:
Code:
#include <EEPROM.h>
#include "eetest.h"
struct config_t
    long alarm;
    int mode;
} configuration;
    configuration.alarm = 12345678;  // comment out after inital eeprom written
    configuration.mode = 1;          // same
    // Write the configuration struct to EEPROM
   EEPROM_writeAnything(0, configuration);  // comment out after first written
// above three code lines could be a function in main sketch to save something away.
    // Read and print the contents of EEPROM
    EEPROM_readAnything(0, configuration);
    Serial.print("alarm  = ");Serial.println(configuration.alarm);
    Serial.print("mode   = ");Serial.println(configuration.mode);
   // A "do nothing loop" where your real working code would be
    while(1)
Lefty
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Code:
    int i;
    return i;
It shocks me that the EEPROM library only handles byte read/writes, when avr-libc provides a simple way to do the above code in ONE library call.
Code:
eeprom_write_block((const void*)&value,(void*)ee,sizeof(value));
Logged
Offline Offline
Newbie
View Profile
You can use the avr-libc call, just put the include in your sketch:
#include <avr/eeprom.h>
But - both routines write 1 byte at a time, so keep this in mind.  The Arduino's EE is only rated for 100,000 writes, you can use that up in a hurry if you aren't careful.
William
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
The Arduino's EE is only rated guaranteed for 100,000 writes
The guarantee includes a retention time.  Atmel makes no mention of "only rated".
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Right, so actually eeprom_update_block is even better.
Logged
Pages: [1]   Go Up
Print
Jump to:
