Topic: How many / What kind of batteries to use for this? (Read 858 times) previous topic - next topic
MonroeD
http://www.sparkfun.com/tutorials/199
This RGB LED wants 650mA per channel, and anywhere between 9 to 30 volts.
It works fine plugged into a 9V wall adapter, but I need to make it powered by batteries.
Would a series of C batteries work?  If so, how many?
Thanks.
TeslaFan
If only there were a magic formula to figure out how many 1.5 volt batteries it would take to equal 9 volts.
Oh! There is! 9 divided by 1.5 equals 6! Take that, Fermat! I'll take that Nobel Prize now, thank you.
Now, as to how long the batteries will last, you'll have to google for that, dividing the total mAh of the batteries by the load of the circuit.
Linux and Arduino, two great things that go great together!
http://www.roboticcore.com
AWOL
Quote
Not quite that simple - a D cell could be rated at 14Ah, but try that as 14 amps for one hour.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
retrolefty
Quote
Quite true. mAh ratings are often a 'marketing' specification. Unless the spec is accompanied with discharge rate and temperature one should take them with a grain of salt.  ;)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
