Topic: using function repeatedly (Read 946 times) previous topic - next topic
Boffin1
I have wasted a day on this, I have before used a function to calculate a result using the same integers and just reloading the information and generating an answer.
I am obviously doing something stupid. I have posted the Mk 999 version below, it has changed many times today..
This time I am trying to scan the commons of 5 BCD switches, by sequentially taking pins 7,8,9 13, and 14 low, and feeding the 4 binary contacts ( through diodes ) to the pins 3 ,4 , 5 and 6  and saving the number as       msg [n]  = address.  for sending by Virtual Wire.
I tried it with linking a wire between 6 and 14 which gives me the predicted 7 on the first loop, and then 15 for the next loops.
When I print the pins it is right , but the address always want to give 15.
I could do it separately, but its bugging me because I have been having some success with functions and arrays lately..  Time to phone a friend :-)
#include <VirtualWire.h>    // Wireless transmitter/receiver library
#include <avr/sleep.h>      // powerdown library
#include <avr/interrupt.h>  // interrupts library
int SW0 = 3;               // bits to read from BCD switches - LSB
int SW1= 4;               // bits to read from BCD switches
int SW2 = 5;               // bits to read from BCD switches
int SW3 = 6;               // bits to read from BCD switches - MSB
int add0;                  // address bits read from switches
int add1;
int add2;
int add3;
int comUnit = 7;    //  outputs to common contacts of the BCD switches
int comTens = 8;
int comHund = 9;
int comThou = 13;
int comAddr = 14;
int comcount;
//int switchbanks = 5;  // change here for number of switches in unit
int pin2 = 2;               // Int0 interrupt pin,  refresh button to ground
int address = 0;            // bits put together afteer reading switches
char msg [5]; // extra char added for address
//                           FUNCTION FOR READING DATA FROM BCD SWITCHES
void checkdata () // read and put together bytes function
 add3 = digitalRead(SW3); // shift it left 3 places
 add3 = add3 << 3;
 add2 = digitalRead(SW2);
 // shift it left 2 places
 add2 = add2 << 2;
 add1 = digitalRead(SW1);
 // shift it left 1 place
 add1 = add1 << 1;
 add0 = digitalRead(SW0);
 // now OR it together
 address = address|add3;
 address = address|add2;
 address = address|add1;
 address = address|add0;
 Serial.print("data for switchbank ");
 Serial.println(address);
 int n = comcount;
 msg [n]  = address;
// *  Name:        pin2Interrupt, "ISR" to run when interrupted in Sleep Mode
void pin2Interrupt()
 /* This brings us back from sleep. */
// *  Name:        enterSleep
void enterSleep()
 /* Setup pin2 as an interrupt and attach handler. */
 attachInterrupt(0, pin2Interrupt, LOW);
 delay(50); // need this?
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);  // setting up for sleep ...
 sleep_enable();                       // setting up for sleep ...
 ADCSRA &= ~(1 << ADEN);
 PRR = 0xFF;
 sleep_mode();                         // now goes to Sleep and waits for the interrupt
 /* The program will continue from here after the interrupt. */
 detachInterrupt(0);                 //disable interrupts while we get ready to read the keypad
 PRR = 0x00;
 /* First thing to do is disable sleep. */
 digitalWrite(comUnit, HIGH);
 digitalWrite(comTens, HIGH);
 digitalWrite(comHund, HIGH);
 digitalWrite(comThou, HIGH);
 digitalWrite(comAddr, HIGH);
 sleep_disable();
// set up the pins as Inputs, Outputs, etc.
 pinMode  (comUnit, OUTPUT );
 pinMode ( comTens, OUTPUT) ;
 pinMode ( comHund , OUTPUT) ;
 pinMode ( comThou , OUTPUT) ;
 pinMode ( comAddr , OUTPUT) ;
 /* Setup the pin directions, write inputs High to turn on internal pullups */
 pinMode(pin2, INPUT);                 // our sleep interrupt pin
 digitalWrite(pin2, HIGH);
   // puts all BCD inputs to input with pullups
 pinMode(SW0, INPUT); // LSB of remote Address
 digitalWrite(SW0, HIGH);
 // byte add0 = 0; // read the value of SW0
 pinMode(SW1, INPUT); // LSB+1
 digitalWrite(SW1, HIGH);
 // byte add1= 0;
 pinMode(SW2, INPUT);  // LSB+2
 digitalWrite(SW2, HIGH);
 //  byte add2 = 0;
 pinMode(SW3, INPUT);  // MSB of address
 digitalWrite(SW3, HIGH);
 //  byte add3 = 0;
 // Initialise the IO and ISR for VirtualWire
 vw_setup(4000);                      // Bits per sec - had to double from 2000 with 8MHz 3.3V Pro-Mini
}                                            // end of void Setup()
 //               wakes up here
 for (int comcount=0; comcount<=5; comcount++ ) {
   switch (comcount)
   case 0:
     digitalWrite (comAddr, LOW);
     checkdata ();
    // msg [0]  = address;
     digitalWrite (comAddr, HIGH);
     break;
   case 1:
     digitalWrite (comThou, LOW);
     checkdata ();
    // msg [1]  = address;
     digitalWrite (comThou, HIGH);
     break;
   case 2:
     digitalWrite (comHund, LOW);
     checkdata ();
    // msg [2]  = address;
     digitalWrite (comHund, HIGH);
     break;
   case 3:
     digitalWrite (comTens, LOW);
     checkdata ();
    // msg [3]  = address;
     digitalWrite (comTens, HIGH);
     break;
   case 4:
     digitalWrite (comUnit, LOW);
     checkdata ();
   //  msg [4]  = address;
     digitalWrite (comUnit, HIGH);
     break;
   case 5:
     Serial.println("Sleep");
     enterSleep ();
   //default:
   }  // end of switch function
 }  //   end of comcount 1-4
 vw_send((uint8_t *)msg, 5);     // send the character out
 //Serial.println(key);                // for debugging only
 vw_wait_tx();                             // Wait until the whole message is gone
 delay (50);
// end of void loop
CrossRoads
John,
The problem might be that I  OR'd the bits together to make the 4-bit address. Once they are set, there is nothing to clear them. I was writing for a static address that came off a DIP switch that didn't change after power on.
Try setting "address" to 0 before calling 'checkdata()'
Boffin1
Thanks Robert,  I didn't want to bug you yet again with a pm :-)
I will try that now
Boffin1
Thanks Robert, I wish I had bugged you earlier now ;-)   seems to be fine .
I should have spotted it I guess, you wont believe the things I tried !
CrossRoads
Yep, you can yourself into all kinds of situations cuttin' & pastin'!
Boffin1
Thats very true, at one point I actually started from scratch but when I got some hassles with that I wondered if I was heading for a dead end, so went back to what I had working in a different form.
When I get caught up and have some time, I will go back without pressure and see if it works.
