Topic: MacBook Pro Serial port (again) (Read 122 times) previous topic - next topic
johankjellgren
Feb 04, 2019, 10:22 am Last Edit: Feb 04, 2019, 11:01 am by johankjellgren
Hi All!
Using a Arduino clone but can't upload new code. Using a macbook pro with Mojave.
Ports do show up (the usb) and I can get board info.
UNO R3 Plus Sensor I/O Shield Development Board Atmega328P ATmega16U2 Multifunctional Microcontroller Module Compatible with Arduino
https://www.diymore.cc/products/arduino-uno-r3-plus-sensor-i-o-shield-development-board-atmega328p-atmega16u2-multifunctional-microcontroller-module-compatible-with-arduino
The board was "preloaded" with the internal / pin13 1000 ms blink
If I run virtualbox with win7 or win10 it works and I can upload and the com3 appears in the dropdown fine so the hardware is fine.
What can I do? I need som kind of port driver?
/ johan
pert
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
johankjellgren
Code: [Select]
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/johankjellgren/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/johankjellgren/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/johankjellgren/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -warnings=all -build-cache /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/johankjellgren/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/johankjellgren/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/johankjellgren/Documents/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10808 -build-path /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -warnings=all -build-cache /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'uno' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10808 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using precompiled core: /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_cache_482982/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a
Linking everything together...
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/sketch/Blink.ino.cpp.o /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/../arduino_cache_482982/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a -L/var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494 -lm
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.eep
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -R .eeprom /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.hex
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-size -A /var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.elf
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem4101 -b115200 -D -Uflash:w:/var/folders/hl/wr69dlz922qb86_k82sylt_40000gn/T/arduino_build_742494/Blink.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2000-2005
         Copyright (c) 2007-2014
         System wide configuration file is "/Users/johankjellgren/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
         User configuration file is "/Users/johankjellgren/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem4101
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
johankjellgren
had to cut some out to get below 9000. it was 9 more fails at the end
johankjellgren
plugged in another cheap clone and now different ports shows up without me setting up anything else.
Now all works perfectly with that clone. original problem still there.
I thought the ports were machine specific not board specific?
