Loading...
Pages: [1]   Go Down
Author Topic: sketch limit size  (Read 595 times)
Offline Offline
Newbie
View Profile
I'have taken this error so many times?
Code:
Binary sketch size: 3414 bytes (of a 14336 byte maximum)
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
It is not an error, it states that the size of the sketch you made is smaller than the amount of Flash memory available.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
how can we fix it?
Logged
Portugal
Offline Offline
God Member
View Profile
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Weird people...
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
how can we fix it?
If you don't compile your program you won't get that message...problem fixed.
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Left Coast, USA
Offline Offline
Sr. Member
Sometimes I just can't help myself.
View Profile
Quote
how can we fix it?
...don't compile ...
Or...
You could paste the following into setup()  5461 times:
Code:
   asm("nop"); // Two bytes worth of doing nothing except burning a clock cycle
Then the compiled sketch size will be equal to the maximum.
Regards,
Dave
« Last Edit: April 27, 2011, 10:50:48 am by davekw7x » Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Unfortunately it would be more than that wouldn't it? - Have you accounted for all of the other rubbish automatically added in?
Logged
Left Coast, USA
Offline Offline
Sr. Member
View Profile
...it would be more than that wouldn't it? ...
Well obviously my post was made with sardonic intent, and I haven't actually inserted 5461 no-ops into anything to make the code size larger.
However, since you brought it up:
Ummm---What extra rubbish?
A nop instruction consists of one word of all zeros.  When I put the asm("nop") instruction in a given program, the program ends up with two more bytes in the text section and no other stuff that I can see.
Am I missing something?  I mean, there are certainly some mysterious things (waiting to bite us in the butt) in the demimonde that we call Arduino, but people have been known to use no-ops to give sub-microsecond delays right?  Do we really have to worry about a bunch of extra rubbish?
Regards,
Dave
Logged
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
Quote
I have, and it only took a couple of minutes!  smiley-grin smiley-grin smiley-grin
I copied and pasted 5461 lines of asm("nop");. It gave:
Quote
Binary sketch size: 11368 bytes (of a 30720 byte maximum)
Onions.
Logged
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) smiley-grin
Left Coast, USA
Offline Offline
Sr. Member
View Profile
Binary sketch size: 11368 bytes ...
My sarcastic comment was about inserting no-ops in the setup() function of a given sketch.  What was the sketch size before you pasted in the no-ops?
Regards,
Dave
« Last Edit: April 27, 2011, 01:59:22 pm by davekw7x » Logged
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
Regards,
Dave
It was 450 bytes. The code was:
Code:
void setup(){
[lots of no-ops]
void loop(){}
Without all the no-ops, the basic code compiles to 450 bytes.
On a more serious point, I am very interested as to how the no-ops function works. I have never heared of the asm() function before, and a google search reveals the American Society for Microbiology. What is it meant to do?
Thanks, Onions.
Logged
Left Coast, USA
Offline Offline
Sr. Member
View Profile
Binary sketch size: 11368 bytes ...It was 450 bytes.
Count again.  I'm betting that you inserted 5459 no-ops, not 5461.  (450 + 2*5459 = 11368)
Since we are being silly, I pasted exactly 5461 no-ops into the setup() function of the Blink example sketch.
Original size was 990 bytes.  With 5461 no-ops, the size is 11912 bytes.  (990 + 2*5461 = 11912)
With an empty sketch like yours, the size went from 428 bytes to 11350 (428 + 2*5461 = 11350)
Note that small differences in absolute code size (428 bytes contrasted with 450)  are undoubtedly due to different compiler versions, but the important thing (if anything in this thread---up to this point---can rightly be called important) is that each no-op increases the sketch size by exactly two bytes, as I previously claimed.  No extra junk that I can see.
Quote from: Onions
The asm() function is not a standard C (or C++) library function.  It is supplied by the compiler/library vendor to allow programmers to insert assembly language instructions in the middle of their C programs.  You can read about it here: avr-libc: Inline Assembler Cookbook
The no-op instruction itself does exactly what its name implies: Does not affect the state of the CPU, i.e. it doesn't change contents of memory or registers or change flags or anything else.  It has to be fetched from memory, like all other instructions, and it takes exactly one clock cycle to fetch the instruction and do nothing else.
What is the asm() function good for?  Well, sometimes people think they are smarter than the compiler and they use asm() stuff to force certain instructions to be executed rather than trust the compiler to create assembly code that is as tight as it can be.  (Sometimes they are even right!)
What is the no-op instruction good for? Well sometimes people need to fine-tune the timing of their programs for various real-time purposes.  For example the SD library uses no-ops in a couple of places to make sure that external setup and hold times are met for certain of the SPI data transfers.  I have used no-ops in assembly language programs where I needed to equalize delay times between different branches of a routine that was generating symmetric waveforms
Stuff like that.
Regards,
Dave
Footnote:
Since the asm() function is not a standard C or C++ library function, its actual syntax requirements may change.  I experimentally determined that the simple form that I showed works for me in this test.  If I were going to use this seriously, I might use the form shown in the avr-libc reference that I gave (which is the form that is used in Sd2Card.cpp in the utility directory of the SD library).
« Last Edit: April 27, 2011, 05:08:17 pm by davekw7x » Logged
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
Thanks davekw7x!
It makes sense now. It is interesting to hear that the no-op actually has a use, and I will remember it for any future codes that need it. That assembly language is complicated - I like it!
Thanks!
Onions.
Logged
Pages: [1]   Go Up
Print
Jump to:
