Topic: switch and multiple interrupts (Read 983 times) previous topic - next topic
cantore
Apr 27, 2011, 10:19 am Last Edit: Apr 27, 2011, 11:34 am by cantore Reason: 1
Hello, I have a rain gauge simply acting like a switch. My circuit is composed by a pull down resistor and a capacitor for avoid bouncing. The problem is that sometimes (not always) the interrupt rutine service (attached on RISING) is called more than once.
Here's what I can see on serial monitor, I print the pin value and " I am in the IRS," when the isr is called. The code doesn't do anything more.
000000000000000000000 I am in the IRS, I am in the IRS, 1111111111111111000000000000000000
Do you think my swith is bouncing but I cannot see on serial monitor something like 00010111100 becuse the ISR is running?
Thanks for your help.
MarkT
Using an RC low pass circuit means you are generating an analog waveform, not a logic signal.  You need a schmidt trigger too (Arduino pins have a little hysteresis and may be good enough, its hard to know).  What's the R, what's the C, how are they wired up?
[ I won't respond to messages, use the forum please ]
cantore
#2
Apr 27, 2011, 12:28 pm Last Edit: Apr 27, 2011, 12:32 pm by cantore Reason: 1
ok, it's true I am generating an analog wave but the interrupt pin are digital so they can only "say": I am under or over a value. I can solve the problem in this software way:
void my_interrupt_handler()
  static unsigned long last_interrupt_time = 0;
  unsigned long interrupt_time = millis();
  // If interrupts come faster than 200ms, assume it's a bounce and ignore
  if (interrupt_time - last_interrupt_time > 200)
   Serial.println("I am in the IRS");
  last_interrupt_time = interrupt_time;
but I cannot anyway understand why 2 ISR are called if printing values I have never changing state like 000010111000 but always non bouncing like 0000011111111100000000...
Thanks for your suggestion
Graynomad
That's not strictly true, there's a grey area in the middle where all bets are off.
Can you post the entire code?
______
Rob
cantore
volatile int vaschetteSvuotate=0;
  sei();
attachInterrupt(1, my_interrupt_handler, RISING   );
Serial.println(vaschetteSvuotate );
delay(3000);
   vaschetteSvuotate++;
This code do not provide any debouncing system. But my question is: why two interrupts occour if the sequence from digital pin rises only once? May be the 0s and 1s that make the ISR happen are not printed on serial monitor but they're lost?
Graynomad
#5
Apr 28, 2011, 10:00 am Last Edit: Apr 28, 2011, 02:55 pm by Graynomad Reason: 1
You will be missing a lot of numbers with this
because most of the values are not printable characters. Change to
Serial.println(vaschetteSvuotate, HEX );
Then at least we can see better what is happening.
______
Rob
