Topic: Play Pause Skip Buttons rmp3 help (Read 982 times) previous topic - next topic
jennyc
Hello,
It has been a while since I have last been here, and have my project running. I have made an mp3 player that analyzes music for frequency and causes a motor to vibrate depending on the frequency that is player, so you can "feel" the music. The project can be seen here http://jennifercrossley.com
I am now trying to get the project to the next step, and need to to be able to "play/pause" and skip track. The white buttons on the device are supposed to be doing this. I have what I think to be the correct code, and have it in my code where I think it should be, I just don't know if it is correct, and how I should wire the hardware buttons to my arduino?
Code: [Select]
#include <RogueMP3.h>
#include <SoftwareSerial.h>
#include <RogueSD.h>
SoftwareSerial rmp3_s(6, 7);
RogueSD filecommands(rmp3_s);
RogueMP3 rmp3(rmp3_s);
int numberOfSongs;
int lastSong;
#define numberOfBands 6
uint16_t bandfreqs[] = { 300, 1000, 9000 };
//uint8_t outputPin[] = { 2, 3, 4 };
uint8_t outputPin[] = { 11, 12, 13 };
uint16_t numfiles = 0;
#define MP3PATH "/mp3/"
// you need to put the two double quotes ("") in the middle below,
// because the Arduino IDE looks for unclosed comments.
#define MP3FILTER "/mp3/""*.mp3"
#define THRESHOLD 1
//#define songname "/gold.mp3"
void checkFrequencies(void)
  // prepare for up to 23 bands
  uint8_t v[23];
  rmp3.getspectrumanalyzer(v);
  for (uint8_t i=0; i<numberOfBands; i++)
    if (v[i] > THRESHOLD)
      digitalWrite(outputPin[i], HIGH);
      digitalWrite(outputPin[i], LOW);
void playNextSong()
  uint8_t i;
  char filename[80];
  char path[96];
  int nextSong = 0;
  if (numberOfSongs > 0)
    // Select our next song randomly
    if (numberOfSongs > 2)
      do
        nextSong = random(numberOfSongs);
      while (nextSong == lastSong);
    else if (numberOfSongs == 2)
      // we only have two songs
      if (lastSong == 0)
        nextSong = 1;
        nextSong = 0;
    // now, get our file name from file list
    filecommands.opendir(MP3PATH);
    for (i = 0; i <= nextSong; i++)
      filecommands.readdir(filename, "*.mp3");
    strcpy(path, MP3PATH);
    strcat(path, "/");
    strcat(path, filename);
    rmp3.playfile(path);
    Serial.print("Playing: ");
    Serial.println(path);
    lastSong = nextSong;
    Serial.println("No files to play.");
void setup(void)
  Serial.println("Started");
  rmp3_s.begin(9600);
  for (uint8_t i = 0; i < numberOfBands; i++)
    pinMode(outputPin[i], OUTPUT);
  Serial.println("Starting sync");
  rmp3.sync();
  Serial.println("Done sync");
    rmp3.stop();
      filecommands.sync();
//void playTrack(void)
//  char mp3path[128];
//  numfiles = filecommands.filecount(MP3FILTER);
//  Serial.print("MP3 count: ");
//  Serial.println(numfiles, DEC);
//  // play a file (random)
//  strcpy(mp3path, MP3PATH);
//  filecommands.entrytofilename(mp3path + strlen(mp3path), 127, MP3FILTER, random(0, numfiles));
//  Serial.println(mp3path);
//  rmp3.playfile(mp3path);
//  rmp3.setspectrumanalyzer(bandfreqs, 10);
//  Serial.println("Playing");
int8_t isPlaying(void)
  return (rmp3.getplaybackstatus() == 'P' ? 1 : 0);
void loop(void)
  //if (!isPlaying())
    //playTrack();
  checkFrequencies();
  uint8_t i;
  char filename[80];
  char path[96];
  int nextSong = 0;
  strcat(path, "/");
  strcat(path, "*.mp3");  // we have to do this because the IDE thinks that "/*" needs to be terminated everywhere
  numberOfSongs = filecommands.filecount(path);
  lastSong = -1;
  char c;
// uint8_t i;
  int16_t newtime;
  playbackinfo playinfo;
  char status = 'S';
  uint8_t playing = 1;
  uint8_t volume = 20;
  uint8_t boostOn = false;
  volume = rmp3.getvolume();  // this only gets the left volume
  playNextSong();
  while(1)
    while(!Serial.available())
      // we should do fancy stuff like flash lights on our Xmas tree here!
      // got lots of time!
      delay(200);
      status = rmp3.getplaybackstatus();
      playinfo = rmp3.getplaybackinfo();
      if (status == 'S' && playing)
        playNextSong();
    // OOH!! got a character!
    c = Serial.read();
    switch(c)
      case 'p':
        // pause
        if(status == 'D')
          // fade in
          rmp3.playpause();
          rmp3.fade(volume, 400);
        else if(status == 'P')
          // fade out
          rmp3.fade(100, 400);
          rmp3.playpause();
          // start playing
          playNextSong();
          playing = 1;
      case 's':
        rmp3.stop();
        playing = 0;
      case 'n':
        playNextSong();
        playing = 1;
      case 'e':
        if(boostOn)
          rmp3.setboost(0);
          boostOn = false;
          rmp3.setboost(8, 6, 7, 3);
          boostOn = true;
      case 'a':
        // jump back 5 seconds
        newtime = playinfo.position - 5;
        if (newtime < 0) newtime = 0;
        rmp3.jump(newtime);
      case 'd':
        // jump forward 5 seconds
        rmp3.jump(playinfo.position + 5);
      case 'k':
        if(volume < 254) volume++;
        if(status != 'D') rmp3.setvolume(volume);
      case 'i':
        if(volume > 0) volume--;
I have commented out parts that I dont think are necessary, but I am not sure.
Any guidance on how to go from here would be greatly appreciated.
Thank you
Jennifer
Gregory_007
Hello
The text was translated because I do not speak English well.
Unfortunately, I can not help you in your question, but you can
can be help.
I have a ump3 is I can not run the command:
filecommands.entrytofilename (mp3path + strlen (mp3path), 127, MP3FILTER,
random (0, numfiles));
I have always an error: code -1.
Do you happen to make it work, if so how?
Thank you
Gregory
robtillaart
#2
May 17, 2011, 12:56 pm Last Edit: May 17, 2011, 03:04 pm by robtillaart Reason: 1
Hi Jennifer,
A quick look revealed
- a bug wrt    numberOfBands  = 6 while the arrays that are associated with it - uint8_t outputPin[] = { 11, 12, 13 }; - only has 3 values
and setup() contains:
   pinMode(outputPin, OUTPUT);
so for some values pinMode (0,OUTPUT) will be called
Choosing the nextsong can be easier
Code: [Select]
void playNextSong()
 uint8_t i;
 char filename[80];
 char path[96];
 int nextSong = 0;
 if (numberOfSongs == 0)
   return;
 if (nextSong == lastSong)
   nextsong = (nextsong+1)%numberOfSongs;
 strcat(path, "/");
strcpy(path, MP3PATH);  <<  MP3PATH ends with a / so next line should not be needed ...
 strcat(path, "/");
Furthermore there is a lot of code that should be moved to setup() as it will give the same values every time.
e.g
 strcat(path, "/");
and maybe checkFrequencies();
The big while(1) in loop() can be refactored out I think. refactoring is rewriting the code without adding functionality only make it clearer.
[ some nonsense removed ]
Do you have a link to the used libraries?
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
#3
May 17, 2011, 04:10 pm Last Edit: May 17, 2011, 05:50 pm by robtillaart Reason: 1
HI Jennifer,
intriged by the application I spend some time tinkering with your sketch. I can't compile it as I dont have the shield or the libs
-- update --> Found the libs, now it compiles under IDE 0022. But still don't have the shield ....
What I did:
- added comments
- moved most vars to global
- moved initialization code from loop() to setup()
- moved lots of code from the loop() to separate functions
- added code for three buttons PIN 3,4,5
These three button must be connected to GND on one side and to their pin on the other side (can be tested just with a wire)
Give it a try
Code: [Select]
// EQUALIZER
#define MAXBANDS 23
#define THRESHOLD 1
// PINNUMBERS FOR BUTTONS
#define NEXTPIN   3
#define PAUSEPIN  4
#define STOPPIN   5
// MP3SHIELD VARS
RogueSD filecommands((Stream&)rmp3_s);
RogueMP3 rmp3((Stream&)rmp3_s);
// EQUALIZER VARS
// TODO size of arrays ???? <<<<<<<<<<<<<<<
 300, 1000, 9000 };
 11, 12, 13 };
// SONG ADMIN VARS
int numberOfSongs = 0;
int lastSong = -1;
int nextSong = 0;
// FILENAME
char filename[80];
char path[96];
// STATUS VARS
char status = 'S';
// SETUP
void setup(void)
 // COMMUNICATION
 rmp3_s.begin(9600);
 // EQUALIZER
// BUTTONS
 pinMode(NEXTPIN, INPUT);
 pinMode(PAUSEPIN  , INPUT);
 pinMode(STOPPIN   , INPUT);
 digitalWrite(NEXTPIN, HIGH);
 digitalWrite(PAUSEPIN  , HIGH);
 digitalWrite(STOPPIN   , HIGH);
 rmp3.sync();
 rmp3.stop();
 // INIT
 checkFrequencies();
 numberOfSongs = filecommands.filecount(MP3FILTER);
   // ALLWAYS START PLAYING
 playNextSong();
// LOOP (endless until power down ...
void loop(void)
 // CHECK FOR SERIAL COMMANDS
 if (Serial.available() > 0)
   char c = Serial.read();
   switch(c)
   case 'p':
     pause();
   case 's':
     stop();
   case 'n':
     next();
   case 'e':
     boost();
   case 'a':
     jump(-5);
   case 'd':
     jump(+5);
   case 'k':
     setVolume(+1);
   case 'i':
     setVolume(-1);
 // CHECK FOR BUTTONS
 if (digitalRead(NEXTPIN) == LOW) next();
 if (digitalRead(PAUSEPIN) == LOW) pause();
 if (digitalRead(STOPPIN) == LOW) stop();
 // playinfo = rmp3.getplaybackinfo();
 // if song ended play next one
   playNextSong();
// TACTILE EQUALIZER I/O
 uint8_t v[MAXBANDS];
// MP3 FUNCTIONS
void playNextSong()
   return;
 // randomize
   nextSong = (nextSong + 1) % numberOfSongs;
 // now, get filename from list
 for (int i = 0; i <= nextSong; i++)
 // and play
void setVolume(int v)
 volume = volume + v;
 volume = constrain(volume, 0, 254);
void jump(int sec)
 uint16_t newtime = max(0, playinfo.position + sec);
 rmp3.jump(newtime);
void boost()
 if(boostOn)
   rmp3.setboost(0);
   boostOn = false;
   return;
 boostOn = true;
void next()
 playNextSong();
 playing = 1;
void stop()
 rmp3.stop();
 playing = 0;
void pause()
 if (status == 'D')
   // fade in
   rmp3.playpause();
   return;
 if (status == 'P')
   // fade out
   rmp3.playpause();
   return;
 // start playing
 playNextSong();
 playing = 1;
Rob Tillaart
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
