Topic: 9 V motor help!!! (Read 974 times) previous topic - next topic
vishalapr
I recently bought 2 9 volt motors which are very powerful and I want to use them on my arduino duemilanove but the arduino can only supply 5 volts so I cannot run the motors on the arduino.
Could you give me some suggestions or some schematics on what to do to make these two motors run on my arduino.And it will be very helpful if you give me a test code to just check that both the motors are running with your suggestions and/or schematics
I am using and arduino duemilanove
I am using it on windows xp
I am going to use the whole thing with the USB connection connected as I want to issue my robot with 2 motors commands from the computer.
I have used the arduino for a bit, but I am still a beginner.
johnwasser
There are various ways to control higher-power and higher-voltage loads on the Arduino.
What control do you need over the motors?  On/Off?  Forward/Off/Backward?  Variable speed?  Variable Speed Forward and Backward?
The most general solution is an "H-Bridge" motor controller.  With two outputs per motor you would have speed and direction control.  Several companies make motor control shields for the Arduino and one of those might be your best solution.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
vishalapr
I just want the motors to go on like this:-
digitalWrite(MotorPin, HIGH);
digitalWrite(MotorPin, LOW);
and/or
for (int i=0; i<=255; i++)
    analogWrite(motorPin, i);
    delay(10);
  delay(500); //Hold it
  for(int i=255; i>=0; i--)
    delay(10);
  delay(500); //Hold it!
Msquare
There is a simple book for the Arduino beginner for download, the last few pages include simple circuits, one of them (pg 34) fulfills your needs.
vishalapr
But I dont have a mosfet could you tell me how to use a transistor (PNP or NPN) to run high power motors.
Thanks
zoomkat
Quote
You might try googling "motor transistor" or "relay transistor".
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Msquare
Thanks
http://tinyurl.com/67vmy25
vishalapr
Yup problem solved using NPN transistors and external battery souece for the motors.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
