Loading...
Pages: [1]   Go Down
Author Topic: Changing NMEA Baud Rate  (Read 697 times)
Offline Offline
Newbie
View Profile
Quick query.
I have a Arduino Uno.
My Idea is inputing NMEA data at example 38.4K baud rate and output it at exsample 4.8K baud rate using the TX (1) and RX (0) pins.
Is this possible? With this board or any other?
Thanks in advance.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Sure - you can use Serial.begin with the new baud rate in between sending and recieving and sending ...
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Someone about 2 years ago was working on a PIC project where several microcomputer boards on a yacht type boat would be the interfaces to engines, electrical management, lighting, winches etc, and talk NMEA 4800 out. The idea was another micro would be a receiver/multiplexor and send all the data to existing display/control systems..  There are commercial multiplexors for NMEA but I don't know if they do other than 4800.
Might be something on boatdesign.net
newsoftserial is very well written bit-bang serial and key to something like this. Are there existing examples of baud rate translation projects??
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
If you wanted to bring in a burst of data via the hardware UART and buffer it up, and dole it out slower via newsoft serial, or adding another hardware modem chip, or using a uC that had more UARTS, that could certainly be done. Implement a protocol to keep the sending from overrunning you while you fed out the slower data.
Depending on arduino model selected, the amount you buffer (in RAM say) would range from small to slightly more unless external hardware was added.
Compare the  Uno/328 to the Sanguino/644 (or upgrade to 1284), Mega1280, Mega2560.
Logged
Pages: [1]   Go Up
Print
Jump to:
