Author Topic: I'm somewhat new would like expert to critique my sketch  (Read 549 times)
Buena Vista, CO
I have not programmed since playing with the original IBM basic. I trying to write a sketch to control the rolling roof on my observatory. I have a motor on both ends and reverse voltage to the motor at the opposite end to the direction of travel to minimize drag. I'm using one of those 8 relay boards you can get on ebay, two switch bricks, three pushbutton bricks and three LED bricks. Voltage reversal is done in how the relays are wired. I'd just like some expert to critique my work. The sketch is at www.alfiesty.com/sketch. Thanks
Jim
8000ft above the average
Netherlands
A naughty mind is a joy forever.
Unfortunately I get a 403  (forbidden, no permission) - error while trying to get access.
Buena Vista, CO
Sorry, I did not post the entire URL. It is www.alfiesty.com/sketch/sketch_roof_control.
Jim
nr Bundaberg, Australia
Same error.
______
Rob
Buena Vista, CO
Sorry, This is the first time I have put a file up on the Internet without help and I screwed it up! Try www.alfiesty.com/sketch/sketch_roof_control/sketch_roof_control.pde
UK
if (bstop = HIGH)
This is an assignment, not a comparison; it will always be true.
if (bismoving = true)//
Ditto.
I'd say if anything, the program is over-commented - this:
Set up Constants
     Digital Pins 0-8 are outputs for relay drivers
     Pin 0 = Out motor 1 out plus
     Pin 1 = Out motor 1 out minus
     Pin 2 = Out motor 2 in plus
     Pin 3 = Out motor 2 in minus
could just as well be put in the declarations of the pins, whilst this:
digitalWrite(openmotoropenplus, LOW);      // sets the digital pin as output
is simply stating the obvious incorrectly.
Generally, it is better to qualify things like pin numbers with "const".
« Last Edit: April 28, 2011, 12:12:01 pm by AWOL » Logged
Buena Vista, CO
 if (bstop = HIGH)
Ditto.
I assume it should be
if (bbstop == HIGH)
All the comments is a matter of style!
Set up Constants
How? Example showing correct would help.
done
Thank for looking, this is my first programming in close to 25 years., I have to say the help provided by the arduino site is great!
Jim (8000 feet above the average)
UK
Well, for a start, it doesn't make the pin an output, it was made an output with a "pinMode".
Your comment might have read "Set the pin low." or "write zero to the pin", but that doesn't describe what that actually achieves, which is what should be commented, if a comment is needed.
Just a stylistic thing, I find long variable names like this
openmotoropenplus
very hard to read, especially when they are in large blocks. I would suggest camel case
OpenMotorOpenPlus
or maybe underscores
open_motor_open_plus
______
Rob
Buena Vista, CO
Thanks Rob, thats a very valid observation. I'll do immediately!
Jim
