Topic: 5 servo motors with 5 photoresistors (Read 937 times) previous topic - next topic
Hedden9414
Hello all,
hopefully i can get some help here.  I am trying to have 5 servos react to 5 photoresistor.  each resistor controls a single motor.  I have it all wired and powering the servos with 10 AA batteries and the arduino is plugged into the wall.  When i run the code below, i dont get any feedback.  However, when i run each servo and photoresistor seperately, they work.  Do i need additional hardware or is there something wrong in my coding?  Any advise will be helpful
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
int photopinA = 1;
int photopinB = 2;
int photopinC = 3;
int photopinD = 4;
int photopinE = 5;
int valA = 0;
int valB = 0;
int valC = 0;
int valD = 0;
int valE = 0;
int pos = 0;
void setup ()
myservo1.attach(6);
myservo2.attach(7);
myservo3.attach(8);
myservo4.attach(5);
myservo5.attach(4);
  pinMode(photopinA,INPUT);
  pinMode(photopinB,INPUT);
  pinMode(photopinC,INPUT);
  pinMode(photopinD,INPUT);
  pinMode(photopinE,INPUT);
  valA = analogRead(photopinA);
  valB = analogRead(photopinB);
  valC = analogRead(photopinC);
  valD = analogRead(photopinD);
  valE = analogRead(photopinE);
  if(valA <= 500)
  for(pos = 0; pos >= -180; pos -=90)  // goes from 0 degrees to 180 degrees
                                   // in steps of 1 degree
    myservo3.write(pos);      // tell servo to go to position in variable 'pos'
    Serial.println(valA);
  for(pos = 0; pos<= 180; pos +=90)     // goes from 180 degrees to 0 degrees
                        // waits 15ms for the servo to reach the position
  if(valB <= 500)
    myservo4.write(pos);      // tell servo to go to position in variable 'pos'
    Serial.println(valB);
  for(pos = 0; pos <= 180; pos +=90)     // goes from 180 degrees to 0 degrees
  if(valC <= 500)
  for(pos = 0; pos <= 180; pos +=90)  // goes from 0 degrees to 180 degrees
    myservo2.write(pos);      // tell servo to go to position in variable 'pos'
    Serial.println(valC);
  for(pos = 0; pos >= -180; pos -=90)     // goes from 180 degrees to 0 degrees
  if(valD <= 500)
    myservo5.write(pos);      // tell servo to go to position in variable 'pos'
    Serial.println(valD);
  if(valE <= 500)
  for(pos = 0; pos >= 180; pos -=90)  // goes from 0 degrees to 180 degrees
    myservo1.write(pos);      // tell servo to go to position in variable 'pos'
    Serial.println(valE);
  for(pos = 0; pos = 180; pos +=90)     // goes from 180 degrees to 0 degrees
Fletcher Chr
Hi Hedden9414
int photopinA = 1;
int photopinB = 2;
int photopinC = 3;
int photopinD = 4;
int photopinE = 5;
You nomenclature for the analog pins are wrong:
Pin mapping
The analog pins can be used identically to the digital pins, using the aliases A0 (for analog input 0), A1, etc.
-Fletcher
MarkT
Negative angles for servo?? that can't work, the value is converted to pulse widths, expect 0 to 180 only to work.
You seem to want to smoothly move each servo in a loop (delay statements missing?) - but to run 5 in parallel you can't code like this, you need to maintain state for each channel and drive them in event-driven manner - you dont have the luxury of hogging the CPU for one servo at a time.
Also you should note the code button (#) for quoting code.
