Topic: PORTB, 3 flashes at startup (Read 162 times) previous topic - next topic
timtailors
Feb 11, 2019, 02:04 pm Last Edit: Feb 11, 2019, 02:08 pm by timtailors
on my ATSAMD21G18A "PORTB,  3" flashes at startup.
Can I disable that somehow?
My test code is
  digitalWrite(30, LOW);
  pinMode(30, OUTPUT);
void loop() {}
variant.cpp
  // 30..31 - RX/TX LEDS (PB03/PA27)
  { PORTB,  3, PIO_OUTPUT, PIN_ATTR_DIGITAL, No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // used as output only
timtailors
#1
Feb 11, 2019, 02:31 pm Last Edit: Feb 11, 2019, 02:45 pm by timtailors
OK, solved that flashing issue maybe. Mapped in variant.h #define PIN_LED_TXL  to an unused pin
A remaining question is if PortA13 has interrupt capabilities? As far as I understood according variant.cpp it should be possible?
{ PORTA, 13, PIO_PWM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM), No_ADC_Channel, PWM0_CH5, TCC0_CH0, EXTERNAL_INT_13 },
MartinL
Hi timtailors,
All IO pins (both analog and digital) on the SAMD21 have standard interrupt capability with the exception of port pin PA08, which is the non maskable interrrupt (NMI).
timtailors
thanks! Does the "standard" also include waking up the device from sleep or is there a kind of "extended" capability necessarily?
MartinL
Yes, each interrupt pin has a wake up capability. The Arduino attachInterrupt() function activates the wake up option by default.
