Topic: USBSerial port reset and lockup (Read 160 times) previous topic - next topic
GordonAnderson
Hello,
I use an Arduino DUE in an instrument controller operating in an industrial environment. In this application I use the Native USB interface to communicate with a PC or MAC running a host application. Most of the time this works fine but I do experience communications errors in some installations, likely due to electrical noise issues. This can lock up the system causing a watchdog timer system reset or rendering the USBserial port inoperable until reboot. I have read similar problems from others and I would like to share a few things I have done and found useful.
My environment is:
IDE: 1.8.7
SAM drivers: 1.6.11
First the following code will reset the SerialUSB interface without the need to reboot the DUE:
 // Reset the serial USB port
void SerialPortReset(void)
  SerialUSB.flush();
  SerialUSB.end();
  otg_disable();               // Disable the hardware
  delay(10);
  otg_enable();               // Enable the hardware
  USBDevice.attach();     // Inits the USB serial port
  SerialInit();          // My serial port initialization code
I modified the USBCore.cpp file and its header, USBCore.h, to address the lockup issues. I found several places where the driver was polling the hardware in a tight loop with no timeout. I added timeouts and a flag to indicate an error had occurred. In the main loop of my Arduino app I poll for this error flag and if found I reset the USBserial interface. My host app then looks for the port to close and reopens in the event of the error.  I added a couple functions to the USBCore.cpp file to help this process, below is my main loop error detection code:
  if(isUSBerror())
    clearUSBerror();
    SerialPortReset();
The functions isUSBerror() and clearUSBerror() I added to the USBCore.cpp file. I have attached a zip file with USBCore.cpp and USBCore.h for reference. You will also notice that I hard coded my ID info for the USB port enumeration process.
This process has worked for me and I just wanted to share what I have learned in case it may help others with the similar problem.
--Gordon
ard_newbie
#1
Feb 11, 2019, 08:19 pm Last Edit: Mar 25, 2019, 08:10 am by ard_newbie
Thanks for sharing.
