Topic: MKR Can Bus transceiver (Read 74 times) previous topic - next topic
Les_Collier
Hi
  is anyone else having trouble with the Arduino ASX00005 Can Bus shield ??
Has anyone used it successfully ??
sherzaad
#1
Feb 13, 2019, 02:22 am Last Edit: Feb 13, 2019, 02:23 am by sherzaad
Hi
have YOU used other CAN bus sheild (the SEED or sparkfun one for example) with other arduinos? did they work.
I personally worked with those and their libraries are OK.
if you did, you could always try to hook up this shield to another arduino and see if it works. (looking at this shield its basically a condensed version of the SEED/Sparkfun ones)
I suspect the problem is more likely software... but since you posted no code...
Les_Collier
Hi
find attached transmit and receive code along with a wiring diagram. I suspect a problem on the transmit side as there is no change in voltage on the network between network standing and network active.
sherzaad
Hi
I donno the board, so I'm asking you this:
I assume you know that a CAN network 60ohm impedance; so, in the wiring you posted, is there 60ohms between the CAN_HI and CAN_LO wires when no power is feeding the circuit?
