Topic: Sharp IR distance sensor as a "button" (Read 2030 times) previous topic - next topic
dingenot
Apr 28, 2011, 11:22 am Last Edit: Apr 29, 2011, 08:10 am by dingenot Reason: 1
Hey, I'm currently working on a project to make a Sharp IR 2Y0A02 sensor to work as a keyboard button in a game. http://www.acroname.com/robotics/parts/R144-GP2Y0A02YK.html
To do this I first wanted to test it with a led and see if I could turn on the led by activating my IR sensor.
I've been looking at these homepages:
http://www.e-gadget.com.au/category/63-arduino-duemilanove-and-infrared-sensor-tutorial.aspx
http://luckylarry.co.uk/arduino-projects/arduino-using-a-sharp-ir-sensor-for-distance-calculation/
So far I've thought of doing it like this. I haven't tested it yet, because I'm not sure that it is correct.
Code: [Select]
int IRpin = 1;                       // analog pin for reading the IR sensor
int ledPin = 10; // Setup LedPin on Digital Pin 10
pinMode(ledPin, OUTPUT); // Initialize the LED pin as an output:
Serial.begin(9600);                    // start the serial port
 if (sensors[0] < 750)
   // Turn on the LED if we get a High Reflectance.
   digitalWrite(ledPin, HIGH);
 // Turn off the LED if we have a Low Reflectance.
 else digitalWrite(ledPin, LOW);
What do you think of this?
At the moment, I'm not sure what I should name the sensors[0] or what distance it should be set at.
Also, do I need to program it to show me the distance time?
Hope you will be able to help me  :)
robtillaart
Welcome in the wonderful world called Arduino ,
First use the # button if you want to publish code  (you can modify your 1st post, select the code and press the #button)
The reading of the sensor will fail, so I rewrote your code a bit so it should work
Code: [Select]
#define THRESHOLD 750
  int sensorValue = analogRead(A0);
  Serial.println(sensorValue);
  if (sensorValue < THRESHOLD )
    digitalWrite(ledPin, HIGH); //High Reflectance.
    digitalWrite(ledPin, LOW); // Low Reflectance.
To improve the stability of the readings, you can repeat them in a loop like in the function below.
Code: [Select]
unsigned int sharpRawAvg()
  unsigned long raw = 0;
  for (byte i=0; i<32; i++)
    raw += analogRead(A0);
    //delay(1);
  return raw/32;
You can add this function to your code and call it from your sketch
replace
with
int sensorValue = sharpRawAvg()
succes,
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
dingenot
#2
Apr 29, 2011, 08:40 am Last Edit: Apr 29, 2011, 09:07 am by dingenot Reason: 1
Thanks a lot, I'm going to try it today :)
I dont know yet what my threshold is, but I'm going to test it today. And I guess I should just use the number I get from that test.
So if this works, should I just replace the
Code: [Select]
int ledPin = 10 and the other ledPin with the keyboard output I'm going to use? I opened a keyboard and took the keyboardchip out.
