Topic: variable temperature controller with AD595 and LCD(2x16) (Read 5733 times) previous topic - next topic
brushless
I have the schematic. Does anybody have PID code for same? I would like to vary setpoint with up/down switches.
bowlerhatman
I don't have any info on your device, but I'm doing essentially the same thing with my brewing thermostat. Here's the code, but there is more stuff in the topic itself.
Code: [Select]
#include <LiquidCrystal.h>
int des = 20;           //set temperature variable
int lastdes = 0;
int tempc = 0;          //temperature variable
int Counter1 = 0;       // counter for the number of button presses
int Counter2 = 0;       // counter for the number of button presses
int State1 = 0;         // current state of the button
int State2 = 0;         // current state of the button
int lastState1 = 0;     // previous state of the button
int lastState2 = 0;
int val = 0;
int pin = 1;            //LM35 input
const int set1 = 1;     //temp up and temp down buttons
const int set2 = 2;
int heat = 0;           //output to heater control
int indicate = 4;       //visual indicator output
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);   // initialize the library with the numbers of the interface pins
  lcd.begin(16, 2);
  lcd.print("SET: ACT: HEAT?");  // Print headings to the LCD.
  analogReference(INTERNAL);
  pinMode(heat, OUTPUT);
  pinMode(indicate, OUTPUT);
  pinMode(set1, INPUT);
  pinMode(set2, INPUT);
State1 = digitalRead(set1);
  State2 = digitalRead(set2);
  if (State1 != lastState1) {
        if (State1 == HIGH && des!= 100) {      //if up button is pressed, add 1 to des
        des++;
  if (State2 != lastState2) {  //if down button is pressed, subtract 1 from des
       if (State2 == HIGH && des != 0) {
       des--;
  analogRead(pin);
  delay(10);
  tempc = (100* (long)analogRead(pin)/1024.0);  //save temperature reading as 'tempc'
  delay(1);                                     //gives a range of about 30
  lcd.setCursor(1, 1);
  lcd.print("    ");     //clear field
  lcd.print(des);     //print set temperature
   delay(50);
  lcd.setCursor(6,1);
  lcd.setCursor(6,1);
  lcd.print(tempc );  //print actual temperature
delay(50);
  if(tempc <= des){                 //if actual temperature is less than
    digitalWrite(heat, HIGH);       //or equal to the set temperature, turn the heater on
    digitalWrite(indicate, HIGH);
    lcd.setCursor(11,1);
    lcd.print("ON ");
    delay(50);
  else  if(tempc > des){             //otherwise leave the heater off
    digitalWrite(heat, LOW);
    digitalWrite(indicate, LOW);
    lcd.print("OFF");
brushless
That code looks just what I need. Thanks a million!
brushless.
BBBOB
Do you have a copy of the schematic and did it work with the code below as I would like to make one and where did you get your sensor please.
Many thanks Bob
Nomiski
Hi I second BBBOB, do you have the Schematic hookup for switches etc.
drPiyush
Code: [Select]
int lastdes = 0;
int lastState2 = 0;
int val = 0;
const int set2 = 2;
  lcd.begin(16, 2);
        des++;
       des--;
  analogRead(pin);
  delay(10);
   delay(50);
  lcd.setCursor(6,1);
  lcd.setCursor(6,1);
delay(50);
    lcd.print("ON ");
    delay(50);
    lcd.print("OFF");
please post schematics.
Thanks.
